> Diagnose my sick engine....
post Jun 3, 2012 - 6:07 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Half way through the 2nd day of this last race my engine started to sputter in the high RPM ranges. 5k+ After service and the engine cooled down it came back to life. About 6 miles into a 10 mile stage the high RPMs started sputtering again.
Then it kept getting worse because I had two 12 miles stages right after that.
As of right now, the car will not idle, if I give it gas the car runs fine even into the higher RPMs until it heats up. I thought it might be spark, but i'm getting spark at least just checking it in my garage.
I also did a compression test and the numbers are good 190/180/180/180
The engine is a 3sge.
This post has been edited by czwalga: Jun 3, 2012 - 6:13 PM
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Jun 3, 2012 - 6:12 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Clogged fuel filter or a vacuum leak?
94 st hatch my daily driver
n
post Jun 3, 2012 - 6:32 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (kurt95gt @ Jun 3, 2012 - 6:12 PM) *
Hmm.... vacuum might explain it. Obviously explains the idle, but wouldnt explain the upper RPM range, until I remembered that the 3sge VVT system is activated by vacuum.
I'll have to go over all the vacuum lines tomorrow.
-10 F150
post Jun 3, 2012 - 6:44 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Shouldn't be VVT in a 3rd gen 3SGE; just ACIS.
Beams has the VVT - no? I'm out of er right now too.
post Jun 3, 2012 - 7:41 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (KAOS @ Jun 3, 2012 - 6:44 PM) *
Yeah the ACIS is what I meant.
-10 F150
post Jun 4, 2012 - 4:24 PM
czwalga
Joined Sep 27, '10
From pittsburgh
No vacuum leak. The more I think about it the idle would go up not down.
-10 F150
post Jun 4, 2012 - 4:47 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Welp.... I just gave the idle screw on the throttle body as good as new.... although something is lurking.
It's also revving fine over 5k now, but I only had the problems after hammering on the engine for like 5 miles straight...
-10 F150
Lo-Fi Version Time is now: November 23rd, 2024 - 5:50 AM
