> Projector Retrofit!, Finally Done!
post Jun 5, 2012 - 12:27 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
***UPDATE***
Check PAGE 2 for Completed Pics!
Finally started work on putting together some projector headlights.
I started out with buying used/not installed Rayme Lenses.
And a spare set of low headlights to do work on.
Months later, last week I purchased Morimoto Mini H1's from TheRetrofitSource.
I was playing around with ideas for shrouds, and tried my hand at vacuum forming.. not bad I guess.
But I'm going to try something else.
Today I got antsy and had to try em out.. took awhile to remove the bumper kind of a PITA
*Note: Shrouds and Clear Lenses not installed yet*
Against the garage the light pattern difference is obvious.
Both.. NOT adjusted yet!
This post has been edited by smkr3w: Jun 13, 2012 - 9:24 PM
3 Pages V   1 2 3 >
Replies (1 - 19)
post Jun 5, 2012 - 6:13 AM
yellowchinaman
Joined Aug 11, '08
From London
where did you get the clear lenses from?
post Jun 5, 2012 - 7:19 AM
smkr3w
Joined Nov 29, '10
QUOTE (yellowchinaman @ Jun 5, 2012 - 7:13 AM) *
I bought em from Jrunik, I believe they were from the Rayme GB..
post Jun 5, 2012 - 12:43 PM
yellowchinaman
Joined Aug 11, '08
From London
So they're not the ones Malhar95 made?
The ones in your pic look pretty clear.
post Jun 5, 2012 - 3:36 PM
smkr3w
Joined Nov 29, '10
QUOTE (yellowchinaman @ Jun 5, 2012 - 1:43 PM) *
No, not Malhars.
His do look pretty similar though.
post Jun 5, 2012 - 3:39 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Looks good!
My Celica!
post Jun 5, 2012 - 8:42 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
what'd you use to get the projector assembly to stay in place in the housing? and what are the projectors out of? I am trying to do the same with some out of an rx350
post Jun 5, 2012 - 10:50 PM
smkr3w
Joined Nov 29, '10
QUOTE (jordisonjr @ Jun 5, 2012 - 3:39 PM) *
Looks good!
Thanks!
QUOTE (cjh4l22 @ Jun 5, 2012 - 8:42 PM) *
The projectors aren't from anything. They're special made for retrofitting. So the thread on the back side of the projector sits snuggly inside the original bulb hole and is tighten buy a nut that is seated perfectly in the back smile.gif
Here:
post Jun 5, 2012 - 10:59 PM
smkr3w
Joined Nov 29, '10
Got the highs done and finished the shrouds today!
A little setback tho the LED strip for the other headlight isn't working properly mad.gif
Gotta contact TRS to see what they can do about getting me a working one.
Once I get that sorted out I can seal the lights, and button her back up!
post Jun 6, 2012 - 12:35 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Loving these lights!!
94 st hatch my daily driver
n
post Jun 6, 2012 - 3:31 AM
smkr3w
Joined Nov 29, '10
QUOTE (kurt95gt @ Jun 6, 2012 - 12:35 AM) *
Question to all you wiring guru's..
Whats the best way to go about wiring the led strips to act in place of my turn signals (ie: running corner lights/ blinkers)??
Strips use 9-12v, has 1 positive wire and 1 negative wire.
Stock turns use 3 wires..
Any help? Thanks.
post Jun 6, 2012 - 12:18 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Wow those high beams look freakin mean!
My Celica!
post Jun 6, 2012 - 4:15 PM
smkr3w
Joined Nov 29, '10
QUOTE (jordisonjr @ Jun 6, 2012 - 1:18 PM) *
Thanks!
Another small update: got in contact with TRS, they should be sending me a replacement strip for the defective one! once I get that she should be ready to light up the streets!
post Jun 6, 2012 - 4:49 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
beautiful lights, minus the led's what did it cost you to make?
post Jun 6, 2012 - 5:28 PM
smkr3w
Joined Nov 29, '10
QUOTE (CAcelica29 @ Jun 6, 2012 - 5:49 PM) *
$120 for Projectors
$25 for LED's
$15 for H1 HID's
$40 for thermoform plastic
$50 for clear lenses
$250 for the whole project.
Bare minimum only would have cost ~150 but I wanted a nice shroud and leds..
post Jun 7, 2012 - 12:00 AM
Syaoran
Joined Jan 4, '12
From US
Is there a link or something where I can get those clear lenses? I also want to do a retrofit but I cant find any clear lenses...
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jun 7, 2012 - 12:16 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Nicely done.
post Jun 7, 2012 - 12:19 AM
smkr3w
Joined Nov 29, '10
QUOTE (Syaoran @ Jun 7, 2012 - 12:00 AM) *
They're custom made but you can try messaging malhar95. He was making them before.
QUOTE (KAOS @ Jun 7, 2012 - 12:16 AM) *
Nicely done.
post Jun 7, 2012 - 1:08 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
yea real great stuff top quality!! for sure
post Jun 7, 2012 - 1:55 AM
smkr3w
Joined Nov 29, '10
Thanks for all the warm replies!
Hopefully can them fully done sometime this week and take some pics on the car biggrin.gif
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: January 10th, 2026 - 3:43 PM
