> Symtech FCD Calibration Help, FML!!!
post Jun 5, 2012 - 10:02 AM
bsamps4
Joined May 16, '10
From Raleigh
Hey guys I just recently installed my symtech FCD, and thought that I was calibrating it properly, but after a few test drives this clearly wasn't the case. I had a situation where I leaned out under boost (I let off the gas immediately), and after some more adjustment all it would do is hit fuel cut. The adjustment screw on this thing will just spin and spin and spin in either direction (I was under the impression that it would stop at full left and full right rotation at some point). The green light on the device comes on in the same spot of the rotation every time, and then shuts off at the same rotation every time.
I ran a line from my compressor to the vacuum hose on my map sensor, and held it with 20 psi, but this thing is so finiky that I can't get the adjustment voltage right. AFter reading what other members have posted, I'm under the impression that I need to set the voltage between 4.10-4.17v. Do i actually need to blast the map sensor with 20 psi to do this? Or can I just turn the calibration knob and use a multimeter until is reads 4.10-4.17v?
Any help or tips would be appreciated. This thing is driving me insane.
post Jun 5, 2012 - 10:31 AM
celica74
Joined Feb 8, '10
From North Carolina
Wont be helping ben get it working unless people post on this. Chime in please!
post Aug 15, 2012 - 10:43 AM
IIRC I had mine at 3.8ish.
You need the 20psi in there and use a multimeter. I used a bicycle pump when doing mine.
post Aug 16, 2012 - 6:23 AM
bsamps4
Joined May 16, '10
From Raleigh
Where did you put the nozzle for the bicycle pump?
post Aug 16, 2012 - 6:31 AM
bsamps4
Joined May 16, '10
From Raleigh
I'm having a weird problem. The car will boost to 20psi no problem, but at around 600 rpms it will hit fuel cut and bounce right back. Its really intermittent, so I can't really figure out what I'm doing wrong here?
post Aug 16, 2012 - 8:01 AM
QUOTE (bsamps4 @ Aug 16, 2012 - 7:23 AM) *
I put the vac hose from the map sensor to the pump, fit and held it perfectly.
post Aug 16, 2012 - 8:34 AM
bsamps4
Joined May 16, '10
From Raleigh
Did you have a basket ball needle or anything like that on the end?
post Aug 16, 2012 - 9:16 AM
I used something like this
I got it at Walmart. Hand pump with a gauge. The vac hose from the bottom of the map fit right in the hole, then used the lever to hold it right in, easy as pie.
Pumped it until it was at 16-17psi on the gauge and noted the voltage the map was giving (without the symtech). Then pumped it to 20 and used the symtech to bring the voltage at 20 to what 16-17 said. Like I said, I think it was 3.8-3.9 but there are a lot of variables like atmospheric pressure depending on your elevation, the season, ect.
post Aug 16, 2012 - 11:14 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
http://gtfour.supras.org.nz/mapsensor.htm
does that help?
Mike W
269awhp / 273ft-lbs
post Aug 16, 2012 - 11:20 AM
delusionz
Joined Feb 11, '08
I've heard st205 ecu fuel dumps at 16psi (but do your own research this is just hearsay)
Anyways, you want to allow the ecu to fuel dump before clamping voltage,
also beware the engine is noisy at 6000 and the knock sensor probably wont pick up knock, also the narrowband o2 sensor wont pick up **** at WOT
Mike W
269awhp / 273ft-lbs
post Aug 19, 2012 - 2:50 PM
malecrod
Joined May 30, '05
From MN
Was getting frustrated with mine. I finally tried Batman's method and that worked for me. With bike pump at 17psi on boost gauge, l got 4.01volts on the multimeter and 4.17v at 18psi. I then dialed the FCD to 4.01v and mine is working now. I think every car is different, because l tried the settings betweent the 4.10 to 4.17volts and kept getting fuel cut.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Aug 19, 2012 - 9:31 PM
QUOTE (malecrod @ Aug 19, 2012 - 3:50 PM) *
Great to hear.
How's the car running ? How do you like the clutch ?
It's different because of elevation, atmospheric pressure, things like that. Summer is different than winter, you might need to adjust again next season.
post Aug 20, 2012 - 11:48 AM
celica74
Joined Feb 8, '10
From North Carolina
do you think humidity would play a big factor?
post Aug 20, 2012 - 9:48 PM
malecrod
Joined May 30, '05
From MN
QUOTE (Batman722 @ Aug 19, 2012 - 9:31 PM) *
Great to hear.
Oh man, Car is awesome!!. Couldn't be more happier. Should have done the 3rd gen swap the first time. Everything on the 3rd gen is just very refined. The clutch is very good as well. So far its the best one yet with no chatter like i used to have on previous clutches. Usually by now I would start having lots of chatter which most of of the time is a prelude to failure. My wife though does not like the feel of the heavy pressure plate which takes some getting used to.
3sgteing.
-Allen Ginsberg-
post Aug 21, 2012 - 1:53 AM
delusionz
Joined Feb 11, '08
whats a safe psi you can run with the fcd, do you have any supporting mods like water injection or something? is it safe to hit 20 pounds?
Mike W
269awhp / 273ft-lbs
post Aug 21, 2012 - 7:59 PM
malecrod
Joined May 30, '05
From MN
QUOTE (delusionz @ Aug 21, 2012 - 2:53 AM) *
Not sure about what psi is safe for the 3rd gen per se, but l do have mine set at 21psi with water injection set to come on at 15 psi. Have top mount intercooler's bottom heat shielded/wrapped, and the intercooler water pump set to run continuously with bigger aftermarket heat exchanger.
Hope it helps.
3sgteing.
-Allen Ginsberg-
post Aug 21, 2012 - 8:02 PM
bsamps4
Joined May 16, '10
From Raleigh
I run 20psi injected from 5psi to 21 psi. My aem is progressive and increases at a linear rate with boost.
post Aug 22, 2012 - 11:33 AM
celica74
Joined Feb 8, '10
From North Carolina
QUOTE (bsamps4 @ Aug 21, 2012 - 8:02 PM) *
straight sex. ever get that thing you talked about the other day figured out?
Lo-Fi Version Time is now: November 27th, 2024 - 2:13 PM
