Strong gas smell, Strong gas smell |
Jun 12, 2012 - 1:19 PM |
Enthusiast Joined Feb 14, '09 From Mid West Currently Offline Reputation: 7 (100%) |
Filled up yesterday. Got home & noticed a strong gas smell in the gas tank area.
Is there a " History " of the tanks getting rusted out in any certain areas or connections // fittings going bad? Before I take it to the shop & put on a lift, it would be good to have the info. I'll check the filler neck areas, fuel line connections // fittings, lines & hoses, & sending unit mount area. Any thing I'm forgetting? Thanks for any tips! |
Jun 12, 2012 - 3:30 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
The seams separate after a while. That's what mine is doing. If I fill it above half, it smells a bit. Not too bad yet though. Not enough for me to get it replaced. My vent neck is also rotted out. My filler neck was rotted when I first bought it, but the owner replaced it when I complained.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jun 12, 2012 - 5:15 PM |
Thanks RabidTRD!! |
Jun 13, 2012 - 3:08 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
My filler neck was also rotting out (only rust on my car luckily), it smelled gas quite a lot when you were near it. Replaced it and no gas fumes anymore.
Jun 28, 2012 - 4:56 PM |
Enthusiast Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
Filled up yesterday. Got home & noticed a strong gas smell in the gas tank area. Is there a " History " of the tanks getting rusted out in any certain areas or connections // fittings going bad? Before I take it to the shop & put on a lift, it would be good to have the info. I'll check the filler neck areas, fuel line connections // fittings, lines & hoses, & sending unit mount area. Any thing I'm forgetting? Thanks for any tips! It's not uncommon for your charcoal canister to rupture and fill your filler lines with the charcoal bits. When this happens the vent on the gas tank has a tendency to get stuck open, and you will smell a strong gas smell. A very good indicator to whether or not this is happening is if you have trouble filling up your gas tank. The gas nozzle would keep shutting off as if the gas tank is full, but you know that it is empty and you are confused why gas won't go in. This is because there are charcoal bits in the filler neck keeping the gas from going in as it is supposed to. I saw this problem on a camry once, other than that I have only seen it on kia's and hyundai's, I've never heard of the celicas having this problem, but you never know. I'm not saying this is your problem, I'm just saying that it is something to look into. -------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
Jul 3, 2012 - 2:01 AM |
Enthusiast Joined Jun 17, '10 From Frankfort Kentucky Currently Offline Reputation: 0 (0%) |
I had to change the gas tank out on mine because of a puncture in the bottom of the tank. The tank I got was from a junkyard and had been sitting in the weather for many years and shows no signs of rusting completely through, just a few spots of surface rust. If it only has a gas smell when full or nearly full I would suspect a one of the various hoses coming off the tank. If it's not the filler hose then pull the fuel pump access hatch under the back seat in order to check the condition of the rubber hoses on the top of the tank. I had to replace all mine because they cracked when I sqeezed them. It could be the charcoal canister but if it was it should have thrown the engine check light and you would be using more gas than usual (the canister cost way more than you would think).
Lo-Fi Version | Time is now: November 28th, 2024 - 1:38 PM |
