Just bought my motor, I have a few conerns nothing serious |
Jun 22, 2012 - 7:13 PM |
Enthusiast Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
Thanks Terrance, I appreciate it man.
-------------------- From Japan to Texas my st202 follows me.
Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Jun 24, 2012 - 12:17 PM |
the oil pump is the same as the 2ZZ-GE, i believe its a YZZ-F1 or F2, which ever is the bigger one. the smaller one works too, its for the 1ZZ engine Whats the difference in the my factory (3fe) and the 3gte, why do I have to change it? -------------------- From Japan to Texas my st202 follows me.
Jun 24, 2012 - 12:53 PM |
Enthusiast Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
Oh i just now thought that alot of us are forgetting you have a 3SFE engine in your car, and its already RHD. Dude most of your swap is going to be differnt from the 5sfe. For example the engine should bolt right up to your car, no probs there. You can re-use your current altenator belt from the 3sfe to the 3sgte. Power steering, A/C, heater core lines should all line up the same way they did on the 3SFE as the GTE.
-------------------- (\__/)
Jun 24, 2012 - 1:00 PM |
Oh i just now thought that alot of us are forgetting you have a 3SFE engine in your car, and its already RHD. Dude most of your swap is going to be differnt from the 5sfe. For example the engine should bolt right up to your car, no probs there. You can re-use your current altenator belt from the 3sfe to the 3sgte. Power steering, A/C, heater core lines should all line up the same way they did on the 3SFE as the GTE. Thanks T, any and all info u have that will help me out with this swap will help, Im doing this al by myself. Tho I have the faith and confidence in myself that I can do it and do it right I would still like any and all help as far as info that I can in this thread so I can refer back. -------------------- From Japan to Texas my st202 follows me.
Jun 24, 2012 - 1:05 PM |
Hey no problem man im here to help. Remember when you were in japan, i told ya i would!
Jun 24, 2012 - 7:00 PM |
Enthusiast Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
You can re-use your current altenator belt from the 3sfe to the 3sgte. Power steering, A/C, heater core lines should all line up the same way they did on the 3SFE as the GTE. I'm not one that likes to correct someone..so I'm sorry..but the belt from the 3sfe can't be used on the Gen III 3sgte, which is what he has. I explored every belt option I could think of and finally I had another member with a Gen III text me a picture of his belt and I cross referenced the part number. The part number above that I mentioned is the belt to use for his engine, the alternator and a/c compressor can be used interchangeably (as well as the Gen IV), but the Gen III has another pulley that is solely a tensioner, making the belt longer. I do believe that what you said is true in regards to the Gen II 3sgte, but the Gen III is a different animal. My belt is actually from some Chevy truck I think. Napa brand 25-050446. -------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
Jun 24, 2012 - 8:50 PM |
You can re-use your current altenator belt from the 3sfe to the 3sgte. Power steering, A/C, heater core lines should all line up the same way they did on the 3SFE as the GTE. I'm not one that likes to correct someone..so I'm sorry..but the belt from the 3sfe can't be used on the Gen III 3sgte, which is what he has. I explored every belt option I could think of and finally I had another member with a Gen III text me a picture of his belt and I cross referenced the part number. The part number above that I mentioned is the belt to use for his engine, the alternator and a/c compressor can be used interchangeably (as well as the Gen IV), but the Gen III has another pulley that is solely a tensioner, making the belt longer. I do believe that what you said is true in regards to the Gen II 3sgte, but the Gen III is a different animal. My belt is actually from some Chevy truck I think. Napa brand 25-050446. No its okay, no hard feelings here. I shouldve watched what i said on that anywho! Also EDIT: As per out PM conversation im going to post this up so that others can offer their advice to this situation in regards to missing your intercooler pump relay and possible wiring, whist trying to keep the stock intercooler system and NOT throw a code 54. First here is someones swap story with a 5SFE. It includes information about axles and im only showing you because you asked initially. Like i said i doubt you would have to deal with these issues. http://www.6gc.net/forums/index.php?showtopic=55058 Alright when it comes to your swap (with wanting to keep chargecooler and running different pump "without" the IC pump relay box) you will have to find where the wires to that relay box are and figure out a way to fool the ECU into thinking that the IC pump is still there so you wont throw a CEL (code 54) for well..you get my point. This is going to be tricky, since you dont have the complete wiring harness that has that relay box Anywho here is a link to a thread on another forum that will give you the idea of what you would of have to do IF you have that relay box.. http://celicas.messageboard.nl/forum/viewtopic.php?t=306 http://www.gt4dc.co.uk/website/development...maintenance.php (code 54 for continuous pump operation) Anywho the easy way would be buying a full and complete st205 wire harness from someone and go from there with the information above.. OR getting an aftermarket ECU (such as the MR2 apexi ECU). I like the latter idea better because that ecu isnt wired to control the WTA system and will still allow you full engine ops capability PLUS tuning options and you can just wire in your new pump to operate off another 12v IGN ON source without the hassles of wiring in resisters and dealing with code 54 issues from anywhere, etc. But the hard and cheap way would be to find those wire and figure out a way to do that resistor trick that is in that 2nd link i sent you. And it sucks from the way i see it, because i would like to give you more advice but i wouldnt know where to start considering im not there lol....but i hope this helps you out somehow. This post has been edited by 3WayStunna: Jun 24, 2012 - 9:42 PM -------------------- (\__/)
Jun 25, 2012 - 7:39 PM |
Also i think this will help you and anyone else out yo!...Pics of the realy boxes and such..
Lo-Fi Version | Time is now: November 26th, 2024 - 10:49 AM |
