Spark Plugs for 3sgte, Part #s etc |
Jun 25, 2012 - 9:29 AM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
Will these sparkplugs fit my 3sgte?
http://www.ebay.com/itm/NGK-Iridium-Plug-S...r#ht_3725wt_952 They are BKR9EIX NGK iridium spark plugs, says 14mm Thread other than that I am clueless as to will it fit in my valve cover or not... is there any part number I have to look for? because heat range 7 and 8 I found on ebay only say BKR7EIX... anyways I Found this online maybe it will help... any other info is helpful... The other plug you mention is actually "ZFR5FIX-11" ZF and BK basically mean the same thing, 14mm, 5/8, extended/projected tip. R means Resistor type plug 5 or 6 being the heat range with a higher number being colder EIX and FIX means Iridium and I believe thread reach with E being a slightly longer reach. -11 and -13 is the preset gat with -11 being like .044 and -13 being .05X, think like .052. This post has been edited by Neon90424: Jun 25, 2012 - 9:40 AM -------------------- |
Jun 25, 2012 - 9:34 AM |
They will fit but the 9 heat range is probably too cold for your application. The BKR7EIX is what you want for a normal 3sgte. Thats one step colder than stock.
Jun 25, 2012 - 9:35 AM |
Im going for 29 psi of boost...
450 hp~ 550 with nitrous... This post has been edited by Neon90424: Jun 25, 2012 - 9:37 AM -------------------- |
i highly doubt that a 5 is the stock heat range. i would say that 6 is the stock range and 7 is 1 step colder. those are high dollar iridium plugs which work good, however since im cheap and change plugs alot, i go with standard copper NGK plugs. BKR7ES
Jun 25, 2012 - 9:39 AM |
nah those heat ranges were for a dodge caliber forum I was more interested in the part numbers and what they meant EDIT:FIXED
Jun 25, 2012 - 10:26 AM |
Im going for 29 psi of boost... 450 hp~ 550 with nitrous... Well those plugs will work, just pick your heat range. 6 is stock and 9 is three steps colder than stock. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: November 22nd, 2024 - 8:04 PM |
