> Air Bag Control Module
post Jan 4, 2004 - 4:45 PM
dcgoalie312
Joined Dec 20, '02
From OKC
is the control module the silver box with the yellow sticker under the center console? thanks
DREW
post Jan 4, 2004 - 4:57 PM
SpedToe169
From Dallas, Tx
Yup, sure is. Be careful!
post Jan 4, 2004 - 5:18 PM
Hym3n
Joined Sep 5, '03
From Grapevine, TX
Yeah, I've got a question about that.. I was taking off the center pieces (with the armrest), and when I pulled it up and saw the box, I was a little shocked, but proceeded carefully. However, attached to my center armrest is a wire, screwed into a little plastic piece, connected directly below where the ashtray is. On the little plastic piece is a lightbulb. After unscrewing this wire from the bottom of the armrest, you have to unclip it from a hinge to take it off..
Now I'm curious, why is there a wire to a light bulb in an area completely un-see-able to anyone in the car? Does it have something to do with the airbag, since it looks like it's coming from that sensor thing..?
-Brian
post Jan 4, 2004 - 6:37 PM
1bwilson
Joined Aug 30, '02
From Maryland
To see your ash tray maybe? Mine truns on when I open it and off when closed.
Member of Team 5sfTe
post Jan 4, 2004 - 7:26 PM
95WRC
Joined Jul 2, '03
From midwest
hey,
the wire is ashtray relayed in some way..
the airbag ecu only uses thick wires in yellow insulation and are double cliped so they won't just pop out so i assure you it is not a sensor wire..
d-
Lo-Fi Version Time is now: February 20th, 2025 - 5:49 AM
