Enthusiast ![]() Joined May 5, '03 From nj Currently Offline Reputation: 0 (0%) ![]() |
Hey guys
Car was overheating. Pulled over twice and let it cool. Still didn't work. Let it sit in driveway for a couple days and filled up coolant. Drove it to mechanic an coolant was leaking out the top of radiator cap. Didn't overheat on drive to mechanic but it was only 5 minutes away. Is this a common problem? Will I need to replace the radiator? Let me know Thx Z |
Enthusiast ![]() Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) ![]() |
Welp, needs radiator cap. Try that first.
It has radiator cap. Maybe it wasn't on tight enough? I'll check that. Anything else that might be the problem?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
BHG?
-------------------- Mike W
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) ![]() |
The cooling system is designed to operate under pressure. If the cap is weak, worn-out or incorrect, its pressure valve will not work. A leaking system isn't properly pressurized, so as said above, start by replacing the radiator cap. It would also be advisable to look for cracks in the upper tank near the cap in case those are the source of the leak.
Basic checks: do the fans kick on when the temperature goes up? If not, there's your problem -- they're supposed to kick on at about 93C. Unplug the temperature fan switch. If the fans immediately start running, then you know the fans are good and you should test the resistance (temperature sensing ability) of the fan switch. Are the upper and lower hoses different temperatures? That usually indicates the thermostat isn't opening correctly to allow coolant to circulate. When you filled the coolant did you properly bleed the air out of the system? Check the coolant and the oil for any cross-contamination (this would indicate a leak in the head gasket). |
Thanks. I'll try that and see if it works.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) ![]() |
Could you give me a more descriptive explanation of where it was leaking. There are numerous simple parts in the cooling system that can go bad and cause the the symptoms you are describing. The more information and detail you can provide the better we can help you diagnose the problem. Going into detail will also make people-who-know-what-their-talking-about more likely to chime in.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
or is there a crack
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) ![]() |
Just read my thread......
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:50 AM |
