A new beginning... |
Jul 15, 2012 - 10:04 PM |
Enthusiast Joined Feb 8, '07 From Connecticut Currently Offline Reputation: 1 (100%) |
The "mz" motor was definitely in mind, I'm pretty sure it bolts up to the E154F trans, correct? I think a supercharger would be pretty fly, something different and something I've never had. I have never read anything about the "gr" motors, are they "easily" swappable or as difficult as trying to swap in a 2jz?
Jul 15, 2012 - 10:18 PM |
Mz will bolt to any trans the 3s
You can use a stock 3s flywheel an clutch kits The wiring will be a nightmare on any of them so if your not good with wiring is suggest sending to someone that is lol The only thing you should have to do custom is a pass (in your case drivers ) side motor mount An if you wanna spend the money smaay makes them Once the rest of my celica is ready is love to super charge my 1mz Tons of power all the way through An with Awd it could be a lot of fun all that off the line torque an no slip . -------------------- 95 gt coupe, v6 swap weekend toy
Jul 15, 2012 - 11:00 PM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
dude, i knew i seen those white wheels before on the shell but couldnt tell from where.. then i seen the beautiful teal 5th gen alltrac hiding in the corner that has happened to be my wallpaper for over a month, thing is bad bro just sayin.. lol .. seen it on "just stance" or some fb photo page (sorry for being weird)
anyways.. good work so far my dude going to be a good project! This post has been edited by Ted95: Jul 15, 2012 - 11:01 PM -------------------- st205 powered ss3 coupe
Jul 16, 2012 - 12:18 AM |
Mz will bolt to any trans the 3s You can use a stock 3s flywheel an clutch kits The wiring will be a nightmare on any of them so if your not good with wiring is suggest sending to someone that is lol The only thing you should have to do custom is a pass (in your case drivers ) side motor mount An if you wanna spend the money smaay makes them Once the rest of my celica is ready is love to super charge my 1mz Tons of power all the way through An with Awd it could be a lot of fun all that off the line torque an no slip . Thanks for the info, I will contact him to see what he offers. I will cross the wiring bridge when I come to a decisionon what motor to put in there, whatever motor I put in, needs to pass emissions no problem when the time comes every two years. One of the main goals of the car dude, i knew i seen those white wheels before on the shell but couldnt tell from where.. then i seen the beautiful teal 5th gen alltrac hiding in the corner that has happened to be my wallpaper for over a month, thing is bad bro just sayin.. lol .. seen it on "just stance" or some fb photo page (sorry for being weird) anyways.. good work so far my dude going to be a good project! Thanks Ted, is your desktop backround from Staggered car show in Somers CT this year? The project should be fun, I just can't wait till it's done! |
Jul 16, 2012 - 12:29 AM |
Well if you go with a 97+ 1mz do yourself a favor an get the whole intake an fuel rail setup off a 94-96
That way you can convert it back to a return style fuel system like the celica uses An if you start n/a with a 1mz a stick gt fuel pump will work as well -------------------- 95 gt coupe, v6 swap weekend toy
Jul 16, 2012 - 2:32 AM |
v6 awd would be kind of cool, gotta boost it though, you'll be taking a massive power cut staying NA.
GT4's aren't all that impressive in stock form either, but then back in it's day I'm sure we **** on Subaru, Nissan, Mazda, anything except Evo2+ for comparable 2.0Ts in Japan in 1994 v6 supercharged awd should be pretty sick, will definitely make light work of those annoyingly long E154F ratios that catch you in turbo lag on tight corners, and that big heavy v6 should anchor the front down a bit more, make that rear end a bit more fun -------------------- Mike W
Jul 16, 2012 - 5:26 AM |
Well if you go with a 97+ 1mz do yourself a favor an get the whole intake an fuel rail setup off a 94-96 That way you can convert it back to a return style fuel system like the celica uses An if you start n/a with a 1mz a stick gt fuel pump will work as well If it matters, I will most likely be running new fuel lines up and down the car but keeping the electronic parts of the fuel setup the same, should I still get the fuel system from a 94-96? v6 awd would be kind of cool, gotta boost it though, you'll be taking a massive power cut staying NA. GT4's aren't all that impressive in stock form either, but then back in it's day I'm sure we **** on Subaru, Nissan, Mazda, anything except Evo2+ for comparable 2.0Ts in Japan in 1994 v6 supercharged awd should be pretty sick, will definitely make light work of those annoyingly long E154F ratios that catch you in turbo lag on tight corners, and that big heavy v6 should anchor the front down a bit more, make that rear end a bit more fun If I go the mz route, I will def be supercharging it. As far as the gear ratios go, is it possible that I could just swap out the final drive for that of a MR2? This post has been edited by FWD-3SGTE: Jul 16, 2012 - 5:27 AM |
Jul 16, 2012 - 9:31 AM |
97+ mz motors have a returnless fuel system so there would be no return line coming off the fuel rail
Since your redoing the whole system anyway you could just layout the whole system like a 97+ Lexus es300 Witch I think has some kind of regulator. Back by the fuel pump Not 100% on that tho That an if you get a 3mz an swap to the 94-96 1mz intake You won't Have to deal with the drive by wire eather. Oh an alil fun fact a a 1mz/3mz with a sc is still lighter than a fully dressed 3s My car now is lighter than it was with the 5s an a/c system still in it -------------------- 95 gt coupe, v6 swap weekend toy
Jul 16, 2012 - 4:20 PM |
97+ mz motors have a returnless fuel system so there would be no return line coming off the fuel rail Since your redoing the whole system anyway you could just layout the whole system like a 97+ Lexus es300 Witch I think has some kind of regulator. Back by the fuel pump Not 100% on that tho That an if you get a 3mz an swap to the 94-96 1mz intake You won't Have to deal with the drive by wire eather. Oh an alil fun fact a a 1mz/3mz with a sc is still lighter than a fully dressed 3s My car now is lighter than it was with the 5s an a/c system still in it I take it you have a supercharged mz? If so, how do you like it? |
Jul 16, 2012 - 4:52 PM |
No my Mz is still n/a
I'm just kind of assuming since I know a n/a Mz is lighter than a 5s So once you add on the extra weight of a turbo to the 3s an the extra waight of a sc to the Mz they should weight about the same with the mz maybe being lighter if you remove the a/c But that being said I live my n/a 1mz it pulls hard from idle to red line But drives no diffrebt than it did before with the 5s When I'm intown I can't even tell the powers there till I hit the gas An if you read my build thread everythingrhat has went wrong has been ny own doing lol -------------------- 95 gt coupe, v6 swap weekend toy
Jul 16, 2012 - 7:31 PM |
Didn't realise it was one of the all alloy motors with plastic manifolds, yeah it should be significantly lighter
Jul 16, 2012 - 7:47 PM |
It's an all aluminum motor . Intake included lol
I liked the fact that it didn't change the way the car handles at all. She still drives like a normal celica till you really push on the gas -------------------- 95 gt coupe, v6 swap weekend toy
Jul 17, 2012 - 2:48 AM |
kurt, how involved is the wiring for the 1mz swap? What harness is started with and what needs to be changed, in a nut shell?
Jul 17, 2012 - 8:09 AM |
To be honest I'm not 100% on what all changes for sure
I know the 6gen fuse box gets wired in the correct plug for the speed sensor Then it has some wiring to deal with the trans codes since most 1mzs were autos An just moving stuff in genral to match where it should run on the celica Smaay could probably tell you a lot more on the wiring I sent mine to Mr220v to have it done. It cost like 350+ shipping both ways -------------------- 95 gt coupe, v6 swap weekend toy
Jul 18, 2012 - 1:11 AM |
Grea, thanks for the info
Does anyone know if the 2GR block and E154F trans will not interfere with each other? That's another motor I came across as a possible swap.. |
Jul 18, 2012 - 8:45 AM |
the 2GR will bolt right up to the E153. no problem. I still suggest you stay away from the 2GR. yes it makes awesome power but they do have a tone of issues that need to be corrected. Personally i would go with a full 3MZ or a 1MZ/3MZ hybrid like i made.
the 3MZ has the plastic intake manifold and has changed over to DBW. it never mated to a 5 speed so you will have to deal with auto codes, although i hear they are easier to defeat over the 2GR codes. the 1MZ did mate to a 5 speed and if you get a solara engine and harness, the ECU is the same one, you just need to ground a single pin and that turns it into a 5 speed. no auto codes. now for the biggest hurdle. after messing with my swap for months now, i can tell you this, if you plan on going AWD with a V6, you will need custom header in the back because the stock header is not going to fit around the transfer case. there is not a lot of room back in there. im still fighting with the header and EGR port and hitting the steering rack. one nice thing about the 3MZ is that there is no EGR, it has VVT, and its a good engine. -------------------- 2001 Celica GT-S Turbo
Jul 18, 2012 - 9:23 AM |
Glad you brought the header up smaay
I was thinking about that an forgot to post anything Although it wasn't my egr that was hitting the steering rack it was my o2 sensor -------------------- 95 gt coupe, v6 swap weekend toy
Jul 19, 2012 - 2:01 AM |
Great info guys, thanks. Smaay, your 1mz/3mz hybrid, did you use a 3mz motor with 1mz intake? What else was swapped, fuel system? What did you do about the oddball motor mount situation? What else am I looking at for hurdles with a mz swap and how are emissions handled? Any regrets for the swap btw?
Whoa, sorry for the questions, not trying to overload you This post has been edited by FWD-3SGTE: Jul 19, 2012 - 2:03 AM |
Jul 19, 2012 - 10:29 AM |
You can handle the mount one of 2 ways
Modifies the stock gt mount with some flat plate steel so it can reach the mounting point on the Mz Or you could always talk smaay into making you a mount like his I know once I got the extra funds I'm gonna have him make me one lol My only regret was not fully knowing what I was getting myself into before the swap Other than that I love it. -------------------- 95 gt coupe, v6 swap weekend toy
Jul 19, 2012 - 3:12 PM |
Great info guys, thanks. Smaay, your 1mz/3mz hybrid, did you use a 3mz motor with 1mz intake? What else was swapped, fuel system? What did you do about the oddball motor mount situation? What else am I looking at for hurdles with a mz swap and how are emissions handled? Any regrets for the swap btw? Whoa, sorry for the questions, not trying to overload you im using the block of the 3MZ to get the 3.3L and the heads and intake of the 1MZ. im using 1MZ electronics and wiring. Because im in the communist California, i have to do it this way. even though the engine is newer than the car, it also must have mated to a 5 speed. as for fuel, i havent figured that out. I want to stay with a return system, but like Kurt mentioned, in 02 the 1MZ was returnless. that means i need to get a regulator and put it in the tank. Im not sure what california will want me to do. im certain ill ahve to add a regulator in the tank so ill have to do with the MR2 guys do. -------------------- 2001 Celica GT-S Turbo
Lo-Fi Version | Time is now: November 22nd, 2024 - 8:17 AM |
