Boosting Beams, Plans and improvement on those plans |
Jul 16, 2012 - 9:29 AM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
triple post
This post has been edited by ricochet1490: Jul 26, 2012 - 5:49 PM -------------------- |
Jul 16, 2012 - 10:24 AM |
the trouble for me has been finding either an after market ecu or a god piggy back and someone to tune the dang thing. The closest I've come is 4 hours from my house and they don't even do toyota..... they're all about audi, porche, VW, etc.... #frustrated There's a shop in Toledo that does toyotas There called accelerated performance -------------------- 95 gt coupe, v6 swap weekend toy
Jul 16, 2012 - 11:24 AM |
Tuning a car isn't that hard, ESPECIALLY when using a piggy back... start from a very safe point (a lot of fuel and very little timing) and increase bit by bit as you go. A stethoscope to listen for knock and a dyno to tune it would be awesome.
A tuner will charge you a **** ton of money for something that he probably doesn't have a clue on how to do. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Jul 16, 2012 - 11:25 AM |
Enthusiast Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
Think ill keep my eye on this thread; See how it develops...
-------------------- (\__/)
Jul 18, 2012 - 7:25 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
theres a booosted Altezza down here...boosted black top... hks everything. came like that from japan
Jul 18, 2012 - 9:12 PM |
Tuning a car isn't that hard, ESPECIALLY when using a piggy back... start from a very safe point (a lot of fuel and very little timing) and increase bit by bit as you go. A stethoscope to listen for knock and a dyno to tune it would be awesome. A tuner will charge you a **** ton of money for something that he probably doesn't have a clue on how to do. That's what worries me, If I end up S/C or T/C, am I going to be able to find a good tuner that won't waste my time or money. And if I can't my learning curve is going to be pretty steep.... Right now I've PM'd a guy about getting a greddy emanage ultimate that he had installed on a 90 alltrac... I'm assuming I could make it work. but at 400$ (what he's asking) it's a pretty hefty investment to be unsure.... -------------------- |
Jul 18, 2012 - 9:42 PM |
The e-manage works on practically any car. You just gotta wire it in. It works on engines with MAFs so it should work on yours.
Jul 23, 2012 - 3:32 PM |
The supercharger idea seems interesting to me, because both the BEAMS and the SC work best at high RPM. Seems like a better match than turbo. May run into mounting issues, since the 3S-GE is tilted back slightly.
This post has been edited by SwissFerdi: Jul 23, 2012 - 3:33 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Jul 23, 2012 - 5:07 PM |
The supercharger idea seems interesting to me, because both the BEAMS and the SC work best at high RPM. Seems like a better match than turbo. May run into mounting issues, since the 3S-GE is tilted back slightly. Should be plenty of space behind the block.... But I agree, the SC may be better. One reason is the lack of turbo exhaust manifolds, or even aftermarket ex manifolds period for the BEAMS. Just depends on if you could adapt cheaper parts that work IF your goals are low amounts of boost. I've been trying to acquire an old GM supercharger off of an old buick regal to see if there is any way to dis assemble and mount it up... namely because those parts are plentiful and one could reasonably get one for cheap if you knew where to look -------------------- |
Jul 24, 2012 - 11:02 AM |
A supercharger isn't better or safer than a turbo. Turbo lets you do much more than a supercharger. If you want the turbo to work at high RPMs only, you can put on a GT35R. If you want to compliment the BEAMS, you can do so with a smaller turbo, have it give the engine a little torque before VVT-i then a huge boost in power when the VVT-i goes on.
The supercharger will take away low-end power in exchange for a tiny bit (compared to a turbo) high-end power... And like I said it's not "safer". It would take a lot more fabrication than a turbo. If you wanted, you could literally weld a flange at the collector of the stock header and put the turbo there. You could cut your stock manifold flange and adapt it to a previous-gen stainless steel manifold (like the 2nd gen 3sgte tubular manifold)... etc etc. -------------------- 1993 Celica GT Coupe - sold
Jul 24, 2012 - 11:39 AM |
If you wanted, you could literally weld a flange at the collector of the stock header and put the turbo there. You could cut your stock manifold flange and adapt it to a previous-gen stainless steel manifold (like the 2nd gen 3sgte tubular manifold)... etc etc. I have all the welding and fab skiills needed for any of this...and this is a heck of an idea. Keep the stock header and 4-2 and 2-1 collector of the stock beams b-pipe, and then put your turbo and turbo flange etc etc under the car. protect it with an underbelly pan like vincent doggy and culpable sell, or make your own.. or put it afte the 4-2 collector and have in the front but down and out of the way towards the front before subframe gets in the way.... Syaoran, nice idea... But also good idea about taking a gen two manifold and adapting the beams mounting plate... I've got all the welders needed for that.... I just ate how it looks. Afte the collector feels like it would be a "cleaner" look. This post has been edited by ricochet1490: Jul 24, 2012 - 11:44 AM -------------------- |
Jul 24, 2012 - 12:59 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Very interested to see how this turns out.
Jul 26, 2012 - 5:58 PM |
what do the pros think?
http://www.ebay.com/itm/Brand-New-GT28RS-A...765&vxp=mtr -------------------- |
Jul 26, 2012 - 10:52 PM |
Jul 27, 2012 - 10:32 AM |
you need atleast a t28 spec turbo for a 2L, that little t25 size turbo will choke at high rpm where the engine would normally flow more air than the turbo can provide, what you will see is 12psi at 2000rpm and slowly go back 11,10,9,8...0psi by 6000rpm
-------------------- Mike W
Jul 27, 2012 - 10:52 AM |
a regular t28bb non-rs would be best bet for a turbo beams, the one on the jdm s15 spec-r or in garretts catalogue "gt2560r"
you really need turbo (low) compression for the gt28rs (gt2860rs) as these things are happy to spool up 22psi faster than your foot can sink to the floor, and thats not the kind of boost you want to be running on a high compression beams motor, so you may aswell save yourself some lag by getting a turbo thats more efficient at lower pressures like 7-10psi which is precisely how the jdm sr20det turbo operates. that plain "t25" size turbo is more suited to a 1.6-1.8L engine running 7psi, to boost peak hp around 200hp which is already what your beams motor makes so provides Nothing at all. the idea of this turbo is to give you the power and torque of a high performance 2 litre NA in a small lightweight 1.6 package. when I chose the turbo for my engine i did alot of research comparing compressor maps, dyno plots. i knew exactly what my goals were in terms of peak power potential, how early torque became available, i had to fit within the limits of factory tuning, i had to have a turbo that spooled early to give me torque outside of (before) the natural 3sgte engine torque band (4000-6000) and also not die off after (6000-7000), and also fit in with my no lag factory w2a setup but not outflow it, etc and while i'm happy to rave about what a great turbo the gt2860rs is, its not the right choice for every 3s setup This post has been edited by delusionz: Jul 27, 2012 - 11:05 AM -------------------- Mike W
Jul 27, 2012 - 8:02 PM |
Delusionz - I wish we had a "thank" button. that helps provide me with a better range to look in. I'm trying to figure out what it all means all at once and it can sometimes be a little over bearing.... steep learning curve
Jul 29, 2012 - 8:21 PM |
http://www.turbobygarrett.com/turbobygarrett/turbocharger
What you'd be looking for is a small turbo that has a higher flow rate at a 1.5 pressure ratio up to 2x. 2x pressure ratio means twice atmospheric, so in other words if atmo(0boost) is 1bar/14.7psi then 2x pressure ratio would be 1bar boost, 3x would be 2bar boost etc... if you work out how much air your engine will ingest on its own at the redline, you need to be well above that with the turbo in order to keep making boost btw i had another look wouldnt let me put this one as an image http://www.turbobygarrett.com/turbobygarre...1&4comp.jpg seems the GT28RS is better than the T28R at low boost AND high boost (my bad) -------------------- Mike W
Aug 4, 2012 - 8:35 PM |
Here's an item you could look into:
http://www.ebay.com/itm/MR2-Celica-T25-T28...9d5&vxp=mtr You could cut the 3s-gte flange off and weld on your BEAMS flange to it, and you'd have a nice manifold ready for a t25 flanged turbo. -------------------- 1993 Celica GT Coupe - sold
Aug 6, 2012 - 12:58 AM |
I did the same thing have the same manifold, ordered 3rd gen flange from the UK and welded it on...
Lo-Fi Version | Time is now: November 27th, 2024 - 9:14 PM |
