> Camber Bolts
post Jul 8, 2012 - 3:37 PM
LALA-shark
Joined Jan 12, '12
From Philly
Im thinking about getting some camber bolts. but was wondering how hard it would be to install and if there is a "how-to" guide for installing them
post Jul 8, 2012 - 4:04 PM
http://www.6gc.net/forums/index.php?showto...4&hl=camber
post Jul 8, 2012 - 4:12 PM
diegohiga
Joined May 4, '09
From coral springs florida US
very simple
http://www.youtube.com/watch?v=8Sr6rc3RH6Q
post Jul 9, 2012 - 3:06 AM
trdproven
Joined Aug 2, '05
From Guam
its pretty simple, most macpherson struts like ours use the same type of camber bolts, especially alot during the mid 90's toyotas. Face the tab toward you to adjust for positive camber, and face it towards the car for negative. its good to have a magnetic camber gauge or those pro ones but i guess you can eyeball it as close as you can to OEM. Just remember OEM specs are not exactly 0 degree there is some degree of camber, and I believe the rears have more camber than the front.
if you have front camber plates on coilovers, you just need to buy camber bolts for the rear.
This post has been edited by trdproven: Jul 9, 2012 - 3:07 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 9, 2012 - 7:34 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I have camber plates on my ksport fronts, but when I adjust the camber (more negative) I also get toe in.
エキサイティングカーレーシングチーム!
post Jul 9, 2012 - 7:40 AM
QUOTE (Tigawoods @ Jul 9, 2012 - 8:34 AM) *
GO GET THE CAR ALIGNED!!!
post Jul 9, 2012 - 7:41 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
it is aligned!!!!!!
エキサイティングカーレーシングチーム!
post Jul 9, 2012 - 1:56 PM
mak5603
Joined Oct 20, '08
QUOTE (Tigawoods @ Jul 9, 2012 - 5:34 AM) *
I'm not 100% but camber bolts in the rear would not do this would they?
2014 Toyota Rav4 XLE
post Jul 9, 2012 - 2:30 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
increase toe when camber is changed?
エキサイティングカーレーシングチーム!
post Jul 9, 2012 - 4:49 PM
mak5603
Joined Oct 20, '08
Yeah.
Edit: I noticed you said going negative. I as referring to going positive, but it shouldn't really make a difference. Just if its toe in or out I guess.
This post has been edited by mak5603: Jul 9, 2012 - 4:52 PM
post Jul 9, 2012 - 6:28 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
toe in an out shouldnt change as extremely, if at all, like mine did when I adjusted my fronts.
Im not 100% sure how toe is affected in the rear
エキサイティングカーレーシングチーム!
post Jul 9, 2012 - 6:46 PM
mak5603
Joined Oct 20, '08
QUOTE (Tigawoods @ Jul 9, 2012 - 4:28 PM) *
Haha, seems we're in the same boat then.
post Jul 9, 2012 - 7:56 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (Tigawoods @ Jul 9, 2012 - 10:34 PM) *
did you notice it after you changed the camber and then dropped the car down from jacks? you'll notice toe changes, you have to drive the car for a little bit for it to settle back, I noticed it myself as well but when i drove it it straightened out.
QUOTE (mak5603 @ Jul 10, 2012 - 4:56 AM) *
IDK but for the most part everytime you touch something in suspension, something changes or gets affected.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 9, 2012 - 9:33 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
it was VERY noticeable. I tried to drive it out but it was TERRIBLE. back to normal setting and waiting to get some bolts, and adjust them from there rather than the top mounts
エキサイティングカーレーシングチーム!
post Jul 9, 2012 - 10:09 PM
trdproven
Joined Aug 2, '05
From Guam
thats actually what I would do...
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 10, 2012 - 6:32 PM
diegohiga
Joined May 4, '09
So our only solution to correct camber are these bolt? I have them but they help just a little.
Obviously we cant adjust the camber bar because is a solid bar, but is there something else that is adjustable to replace that bar? Or the only solucion is to cut the bar, short it and weld it?
post Jul 10, 2012 - 7:44 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
my rear camber can be adjusted via the top mounts, but it isnt fine tune adjustment like the front. there are set holes where the top mount bolts thread through at certain degree's. Other than that, for fine tune, I would say thats where the screws come in.
エキサイティングカーレーシングチーム!
post Jul 10, 2012 - 10:36 PM
trdproven
Joined Aug 2, '05
From Guam
there are camber bolts with more degree adjustments just look for those, most of the market has 1 degree or 1.75 degree or something like that. get somewhere in the 2-3 degrees. our camber bolts are mainly for struts similar to ours which was prominent in the 90s. if our cars had upper arms that would have been more adjustment but also more expensive.
This post has been edited by trdproven: Jul 10, 2012 - 10:37 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: January 10th, 2025 - 6:06 AM
