> Starter cable grounded on trans, le sigh...
post Jul 9, 2012 - 10:34 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
MR2V6 content, but subject matter is universal I think.
So yesterday while leaving my driveway my car shut down on me. When turning it back to the ON position my tach wasn't doing its sweep (LinkECU start-up). Then I saw the smoke coming out from the engine lid. When I popped it open I could see the smoke was coming from the starter wire. Apparently it had grounded into the shift linkage on the transmission and roasted my battery (that poor Optima frown.gif )
Fast forward to this afternoon. I put a new battery in and it was very sluggish to turn over, but it did and started and ran fine. So I yanked the starter off and replaced it with a new unit... and the sluggish starting continued.
I am going to pull off the alternator and take it in to NAPA to get it tested/replaced... thinking the built-in voltage regulator might be fried on it. Is there anything you guys can think of that I am missing here? Or am I on the right track with this? I guess I've never roasted my electrical system before... rolleyes.gif
**** Photobucket
post Jul 9, 2012 - 11:10 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Check your wiring -- good chance something else was cooking and burnt wires tend to produce connection issues.
post Jul 10, 2012 - 6:54 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Good chance the ground got roasted with the battery cable
post Jul 10, 2012 - 8:07 AM
95CelicaST
Joined Feb 5, '05
Going to purchase new battery cables today to rule that out.
**** Photobucket
post Jul 11, 2012 - 9:31 PM
95CelicaST
Joined Feb 5, '05
Replaced ground wire at the battery this evening. Cleaned up the chassis point as well. Still no go.
I then disconnected the battery and ran jumper cables from it to the starter and grounded on the engine... No change. I figured that would be an effective way to bypass the positive battery cable. I tried two known good batteries with no change.
I'll be putting a multimeter to it tomorrow to find where the resistance is at.
**** Photobucket
post Jul 12, 2012 - 6:25 PM
Special_Edy
Joined Oct 29, '11
Sounds like the starter is toast. If thats the case it is much easier to replace than wiring thumbsup.gif
post Jul 12, 2012 - 10:07 PM
95CelicaST
Joined Feb 5, '05
I had replaced the starter already. That was troubleshooting step one.
Today I pulled off all of my 4ga ground cables from the engine and found that one had become VERY oxidized. I sanded down the ends of the cable and reinstalled and now it's starting perfect again. Drove home and had no issues.
**** Photobucket
Lo-Fi Version Time is now: December 4th, 2024 - 2:19 PM
