GT4 alignment, moves a bit to the right |
Jan 5, 2004 - 10:28 AM |
Enthusiast Joined Oct 24, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
My GT4 was an accident car. The roof was destroyed when it went in a ditch or something. There was some chasis damage but i took it to my friends bodyshop and replaced the roof and he fixed all problems. He put the car on the press and the car shows that the chassis is o.k after he fixed it.
The problem is that i took the car for wheel alignement but there were not any screws to align the rear tyres. I only aligned the front tyres. the steering wheel is a bit to the right and the car in general goes to the right a bit. By the way, there is a small crack on the right bushing -suspension .(The rubber stuff that you can see from the engine bay.) I need to know what the hell is wrong. Do you think it is a problem relating to the chasis or probably there is some damage in the suspension? Did anyone had a similar problem |
Jan 5, 2004 - 1:00 PM |
Enthusiast Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
The car is definitely still tweaked some. Just because it is 'within spec' on the fram jig doesn't mean its truly straight. I don't know enough about the GT4 suspension to be able to tell you how it aligns, but the USDM celicas are fully adjustable in the back.
Did you do a full alignment? Camber/toe/check caster? If not then it could be a camber problem causing the car to pull to one side. |
Lo-Fi Version | Time is now: November 25th, 2024 - 6:32 AM |
