5 Pages V  < 1 2 3 4 5 >
> Because RACECAR!!
post Aug 7, 2012 - 2:43 PM
ricochet1490
Joined May 3, '11
From Ohio
After a few weeks this is what it looks like...
post Aug 7, 2012 - 2:48 PM
glad to see that adapter changed hands again, i should have signed it, and made more and then world domination.
post Aug 8, 2012 - 1:15 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
This, Is a celica?!
Da fuq? lol.
My Celica!
post Aug 8, 2012 - 8:23 PM
ricochet1490
Joined May 3, '11
From Ohio
QUOTE (jordisonjr @ Aug 8, 2012 - 1:15 PM) *
This, Is a celica?!
Da fuq? lol.
I'm glad someone asked.....
NOOO! this is a late model dirt car, rear wheel drive, 500+ horsepower crate motor, it'll be the other car we take to the track come race night.... Celica be on the other trailer lol
post Aug 9, 2012 - 5:33 AM
yellowchinaman
Joined Aug 11, '08
From London
post Aug 20, 2012 - 9:01 PM
post Aug 20, 2012 - 9:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
2001 Miata LS 5-speed
post Aug 28, 2012 - 5:17 PM
ricochet1490
Joined May 3, '11
From Ohio
I'll just leave this here from yesterday...
post Aug 30, 2012 - 9:48 AM
rollcage!
post Aug 30, 2012 - 10:31 AM
amazing!!!
post Aug 30, 2012 - 8:50 PM
ricochet1490
Joined May 3, '11
From Ohio
post Aug 30, 2012 - 10:54 PM
mkernz22
Joined May 10, '10
From MA
Just kidding. I see that you're going to be welding a panel on there instead of having an actual door.
post Sep 10, 2012 - 9:44 PM
ricochet1490
Joined May 3, '11
From Ohio
post Sep 10, 2012 - 10:43 PM
turnip
Joined Aug 24, '09
In regards to LSD vs weld. I recommend welding as it's Just plain better on the dirt. After 3 celicas an 5 years of racing on the dirt there is no comparison as Welded trans will outperform LSD. The one caveat is each tracks rules. Some say no welded. However most tracks don't check or even care to enforce the rules. I have run some very small tracks an ur concerns in regards to tight turns r valid for a welded diff but even the 1/4 mile tracks r not an issue. Key is tires an suspension. The super strut is great but not worth the headache. The unreliability is a fact. If I get thru this season without a wheel coming off I will be surprised. It was good to test it out but going back to stock cause I need parts an finding them will be an issue an not worth the expense. Sorry I have been MIA. Will post up some pics soon an give me a call with any questions. I have built 3 of these an can give u a lot of pointers. Maybe we can race at Tyler county next spring.
post Sep 11, 2012 - 6:48 PM
ricochet1490
Joined May 3, '11
From Ohio
QUOTE (turnip @ Sep 10, 2012 - 10:43 PM) *
If you're going to be at TYLER COUNTY i will most def be there. That's like an hour from my house. Where in general are you coming from?
But thanks for the heads up on the welded. I wouldn't have thought the difference would have been that much. Post up some pics of how your car looks.. Inside... outside.... fuel cell...we're trying to figure out what all we're gong to do with this one... make it look like a late model maybe LOL
The tracks around here say that welded differentials are allowed... so I think I"m good there.
post Sep 14, 2012 - 9:34 PM
turnip
Joined Aug 24, '09
Sounds good on racing in the spring at Tyler County. I race at all around western PA and Western MD.
I will round up some pics but if you pull my old build thread you can see the cage install. We have been using the same cages for the other cars. I fabricated a trick quick disconnect for the steering wheel retaining the stock steering wheel and I recommend retaining the power steering vs eliminating it. Only run OEM axles....rebuilds from advanced will last about one race. Im running stock fuel tank vs a fuel cell.
post Sep 14, 2012 - 10:06 PM
richee3
Joined Jun 29, '08
From Denver
I've just had a thought. I know the BEAMS and 5S use the same 190 lph fuel pump, but considering how much time you will spend at WOT or at least above 50% throttle, you might consider a new fuel pump. I know the stock fuel pump takes a second to build pressure back up, so a newer fuel pump might not be a bad thing. Low fuel pressure is never a good thing. Of course, I'm sure you've already thought of this since you're two steps ahead of me
The cage is looking great! I'd love to make it up to the race between you two. Keep me updated and I'll check my schedule!
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 15, 2012 - 1:59 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
post Mar 14, 2013 - 7:44 AM
ricochet1490
Joined May 3, '11
From Ohio
Updates coming this weekend...
post Mar 14, 2013 - 3:55 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
bout time!!!
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: April 29th, 2025 - 7:16 PM
