> tire wear, I need some help
post Jan 5, 2004 - 2:43 PM
Phr0z3n664
Joined Oct 20, '02
From Covington, La
I have a question about the tire wear on my car.
I needed to buy some new tires a few months ago, and within 3-4000 miles they are bald on outside of tire on the driver side, and on the inside of the passenger side of my car. frown.gif
Do I have a camber or alignment problem? Or am I just taking turns to hard to the left?
Please help me out I need some answers this week so I can have this prob fixed before I buy new tires for my new wheels.
post Jan 5, 2004 - 3:09 PM
blkGT
Joined Jun 10, '03
From FL
happened to me, i got an allignment and it stopped. thats all i can say
post Jan 8, 2004 - 3:03 PM
klr_toy
Joined Feb 18, '03
From Hermiston, OR
ya I would say you need an alignment. If the car hasn't been wrecked an alignment should fix it.
post Jan 8, 2004 - 4:36 PM
crazy95
Joined Dec 23, '03
It all depends on if you lowered you car also. I would say just an alignment but if you did lower your car then it would most likely be your camber caster. You would need to get a kit for that and its farely cheap.
Go with the alignment first though and if you see a dif wear pattern in the tires after 3 weeks or so then get the camber kit
post Jan 8, 2004 - 5:44 PM
ghostdog
From ny to philly
QUOTE (crazy95 @ Jan 8, 2004 - 4:36 PM)
any decent alignment should include adjustment of camber/caster. also our cars don't require a special kit, it comes adjustable from factory.
as for your tire wear question. it definetly has to do with your alignment. its probably out of wack if you've lowered your car or your suspension has taken a beating.
post Jan 10, 2004 - 12:59 PM
ConeTrouble
Joined Nov 25, '03
From Mizzeri
It is likely that your alignment is out of whack, but you should also check your tire pressure. If it gets low, you could be rolling over onto the sides and wearing the outside edge prematurely. I see this a lot, actually, because many people do not realize that cold winter weather can sap as much as 10psi from your air pressure compared to the summertime.
This is probably not the culprit, as it doesn't explain the wear on the inside of the passenger side, but I thought I would mention it nonetheless.
Lo-Fi Version Time is now: February 21st, 2025 - 9:24 AM
