5 Pages V  < 1 2 3 4 5 >
> Big Brakes and 7th gens, We got big news! The party boat is here!
post Apr 27, 2004 - 7:35 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
you need 16 inch wheels or bigger for the big brake kits
defgeph
I will return one day.
post Jun 4, 2004 - 1:03 PM
oOoHuY
Joined Nov 12, '03
From h town
io was woundering how i would do the rear drum brake conv... what do i need to make them brakes thanks
post Jun 4, 2004 - 4:11 PM
SpedToe169
From Dallas, Tx
Step 1: Do a search.
post Jun 11, 2004 - 4:43 PM
edo17982
Joined Dec 21, '02
From Italy
QUOTE (SpedToe169 @ Apr 28, 2004 - 2:00 AM)
Ok, let me clear this up. If you get the 7th gen rotors, you must use the 7th gen calipers (and caliper hangars, what you're calling torque plates i guess). You CANNOT use the 7th gen rotors with the 6th gen calipers.
what about the opposite thing?
I mean...may I keep my drilled/slotted ST rotors and use 7th gen calliper?
also...are pads same or not?
post Jun 11, 2004 - 6:56 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
I do not think you can. The 7th gen rotors are bigger which mean the pads are bigger... You can try it, but I don't think some of the pad(7th) will be on the rotor.
post Jun 11, 2004 - 8:47 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
ok this started out very confusing, but i think it is pretty much cleard up
my prob. now is that the brembro BB kit is for front only right and how much is it
i think it's expensive, but i may be thinkng of AEM
i want to know if the SSBC parts in the following link (mainly the 2piston w/13" rotors for front kit and the rear kit) will fit to my celica (95 st) without any other parts needed, if you do need other parts, what are they and are they expensive
ssbc
dangit, the link won't work so just put in the make model and year (i put 01, is this ok) and it will take you to the kits i am refering to
This post has been edited by celicaracer18: Jun 11, 2004 - 8:49 PM
post Jun 12, 2004 - 11:14 AM
drdos
Joined Aug 19, '03
From Buffalo,NY
i persoanly think the bremo BB kit would be a stupiida idea for our car;.s unless you have a 3sgte swap pushing more then 350+ hp
post Jun 12, 2004 - 11:55 AM
how about using the ST185 calipers on a GT?
i have all 4 calipers from my clip and need to know what needs to be done to make them work with my car. the ST185 has dual piston calipers, and 5th gen guys claim its an easy swap for them.
post Jun 12, 2004 - 9:01 PM
remjay
Joined Nov 13, '02
switching to the 7th gen brakes or using brake kits designed for any other generation is not the best of ideas. You will throw off the the brake bias and probably even hinder braking performance.
post Jun 13, 2004 - 9:06 PM
Jeremy1210
Joined Dec 16, '02
if you did switch to another generation celica, I think that you would have to get an after-market brake adjustable proportioning valve or the one from the generation that you switched to. That is so the proper amount of fluid goes to the wheels correctly.
I think speedtoe told me about this when I was asking about this, and I also think that he bought an after market APV for his ST
Jeremy
post Jun 14, 2004 - 8:08 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
QUOTE (celicaracer18 @ Jun 12, 2004 - 1:47 AM)
ssbc
does anyone know if this will fit
post Jun 15, 2004 - 3:21 PM
oOoHuY
Joined Nov 12, '03
From h town
ok so basiclly what all these comments lead to that a 7gc front brakes are able to be tranfered right on a 6gc correct because reading all the big brake kit thing confuse byt yeah thats all i have to ask so it would clear it up.... also i have searched on about if a 95 st rear disk drum can be converted in to brake disk and no luck but yeah answering my question would help alot thanks
post Jun 15, 2004 - 7:57 PM
Jeremy1210
Joined Dec 16, '02
You haven't tried hard enough. Look in the "How to" next time.
Anyway, I did the swap back in march. Works great. Read the "How to article" and if you ahve any questions let me know.
Jeremy
post Apr 6, 2005 - 9:49 AM
nightrider
Joined Apr 26, '04
From London
I have been told by TRC that there is no compatibility between 7th and 6th gen rotors? Does anyone have model and manufacture part numbers or better still any pics!!! I would love to fit a NOS system but my brakes can just about stop me with my current mods. They would not have a chance with NOS on board.
More Power to your BOOM BASS
post Apr 6, 2005 - 1:55 PM
As far as I know, no-one has done this. Who's TRC? Do you mean TRD?
The rotors would be different, so you'd need to swap calipers too.
post Apr 7, 2005 - 7:20 AM
nightrider
Joined Apr 26, '04
From London
I cannot find a big brake kit that fits 100%, companies are stating that thier kits for 7th gen will not fit on 6th gen ST202 models?
post Apr 7, 2005 - 11:24 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
i'd PM speedtoe and see if he ever solved this riddle
post Apr 7, 2005 - 3:58 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(nightrider @ Apr 7, 2005 - 12:20 PM)
[right][snapback]267661[/snapback][/right]
That depends on what version ST202 you have. It will not work with the Super Strut versions, but will with the Macphearsons. As for companies, most tele reps don't know much about cars and such, so unless you're talking to one of the designers... they really can't tell you anything.
post Apr 7, 2005 - 3:59 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Consynx @ Apr 7, 2005 - 4:24 PM)
[right][snapback]267756[/snapback][/right]
It's not much of a riddle... all that needs to fit is the caliper. The rotor, I'm positive will work. So long as the caliper bolts up, it's pretty much a done deal. I'm about 90% sure the 7th gens share the same knuckle pattern as the 6th gens.
post Apr 12, 2005 - 6:50 PM
racingmcfly
Joined Jun 14, '04
From Wimborne Dorset England
QUOTE(Kwanza26 @ Apr 7, 2005 - 8:59 PM)
[right][snapback]267888[/snapback][/right]
Anyone got a set of Power slot big brakes for a gen 7 to fit a gen 6?
http://www.powerslot.com/cat_apps/trucks.htm
Ive got a set of GT4 ST205 calipers and discs but now I find they dont fit im looking for an alternative.
Lo-Fi Version Time is now: November 23rd, 2024 - 7:24 AM
