Rebuild kits?, Some help finding quality parts |
Jul 17, 2012 - 10:13 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I know this isn't the best rebuild kit for the 7A out there, but where could I find something similar in better quality?
http://www.ebay.com/itm/360320374913?ssPag...9#ht_4249wt_986 -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Jul 17, 2012 - 10:28 PM |
http://www.importperformanceparts.net/impo...ekits-toy1.html
Search also in that same site: part# EKTO29MPX -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Jul 17, 2012 - 10:35 PM |
I'm on my phone, but I'll search that # later tonight. What is it exactly?
This post has been edited by HectortheRican: Jul 18, 2012 - 1:14 AM -------------------- taking too long to mod since '09
Jul 17, 2012 - 10:39 PM |
The EKTO29MPX is a HP engine rebuild kit. It includes the following:
Complete Gasket Set MLS Head Gasket ROSS/Wiseco Forged Pistons (81, 81.5, 82mm bore) and (any comp ratio) Performance Rings Performance Wrist Pins TOGA HP Main Bearings TOGA HP Rod Bearings Timing Belt Freeze Plugs Thrust Washers For a few bucks more you can have a Toga High Vol. Oil Pump, but I'd go with the OEM one. -------------------- 1993 Celica GT Coupe - sold
Jul 18, 2012 - 12:44 AM |
Just to be certain, if I get 0.04" oversized pistons, that's diameter, right? If so, what size bearings should I buy to go with them?
Jul 18, 2012 - 1:07 AM |
Just to be certain, if I get 0.04" oversized pistons, that's diameter, right? If so, what size bearings should I buy to go with them? If you don't need oversized pistons (in the case of the cylinder walls being good to go with a hone) I recommend you don't get them. Later on something might happen and you have already used all the wall meat you could safely use. If you also plan on going some kind of forced induction later on perhaps, having stock bore is best. But yes, .040" means 1mm larger in diameter, so you would be I believe 82mm instead of 81mm stock. That kit also lets you choose piston static compression. So you could go 9.0:1 for a decent FI build, or 9.5:1 for a stock rebuild, or maybe 10.0:1 for a little more compression for an mild N/A build. Mind you, that kit does not include a water or oil pump I believe. You should contact them with the part # of the kit and ask what exactly the kit will bring. Granted you'll get good quality parts that meet or exceed OEM specs for a decent price. -------------------- 1993 Celica GT Coupe - sold
Jul 18, 2012 - 1:13 AM |
Yeah, I figured that'd give me trouble down the road. I was just curious, so I thought I'd ask. So you're talking about the $900+ HP kit, right? What about the $455 Bronze kit? Is that one not good enough? Certainly seems better than the cheap eBay one that I linked. I just want an OEM-spec rebuild. Maybe I'll advance timing 10 deg or so and start running premium to get a little pep, but that's all.
Jul 18, 2012 - 1:20 AM |
Jul 18, 2012 - 1:34 AM |
Hmm, ~$115 less than the other one and only doesn't have a water pump. However, that's not a big issue; my current water pump only barely has 20k miles on it, as does my timing belt and tensioner pulley. -------------------- taking too long to mod since '09
Jul 18, 2012 - 1:37 AM |
With only 20K on it, should be ok. Though if you do feel like getting one anyway, RockAuto has one for $18 that includes the gasket.
This post has been edited by Box: Jul 18, 2012 - 1:38 AM -------------------- 2001 Miata LS 5-speed
Jul 18, 2012 - 9:25 AM |
Damn, that's a cheap water pump. The rebuild kit comes with a new belt, so I might as well spend the extra all of $20 to get a new water pump.
Jul 18, 2012 - 12:00 PM |
Enthusiast Joined Feb 8, '10 From North Carolina Currently Offline Reputation: 0 (0%) |
the hp kit is if you looking to do more work to the motor, also notice it comes with forged pistons 20 or 40 over at any comp you want. i also believe the bearings will hold up better to more power as well. im looking to get one pretty soon.
Jul 18, 2012 - 3:05 PM |
thats alot of overkill, what exactly are you trying to do? unless you are planning on making huge power, you dont need aftermarket ppistons. are your internals damaged?
bearings have nothing to do with piston size -------------------- 2001 Celica GT-S Turbo
Jul 18, 2012 - 3:28 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Putting in new pistons when rebuilding is not overkill Jeff... It is not required when rebuilding but if you can for a decent price (like hector car) you defiently should as the OEM skirts may have worn, or the pins, or who knows what. Do it Hector
This post has been edited by SupraKid: Jul 18, 2012 - 3:30 PM |
Jul 18, 2012 - 3:59 PM |
i didnt say new, i said aftermarket. why spend a ton of money for wiseco pistons when you can get .020 OEM pistons for about 60 bucks each. yes if there is wear then those should be used.
Jul 18, 2012 - 5:35 PM |
I was going to embark on rebuilding the motor, but I found a local shop that's been here for a very long time that sells rebuilt motors. They have a totally rebuilt 7A with 0.020 pistons, new oil/water pumps, new timing belt/tensioner pulley, new rings, new bearings, new valves, new stem seals, new F/R seals, and all new gaskets for $1,000 and it comes with a 1yr/12,000 mile warranty. Seeing as how I'd be spending $850-$900 rebuilding myself, I don't mind fronting an extra $100 for piece of mind and a warranty. I'll be putting it in myself, though! Staying in the Celica game!
Jul 18, 2012 - 5:57 PM |
Hooray!!!
Jul 18, 2012 - 6:12 PM |
That's nice.
Jul 19, 2012 - 11:38 AM |
honestly sounds like a hell of a deal. jump on that
Lo-Fi Version | Time is now: December 4th, 2024 - 8:15 PM |
