> Amp Install, Help Please
post Jan 6, 2004 - 6:00 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
Can some one tell me how to hook up and amp to a sub. so far I ran wires from back of H.Unit to Amp, Wire from Battery to Amp, Ground to Amp, Sub to Amp. I hooked it all up and for some reason the amp doesn't turn on the fuse is good and I can't figure it out.
Thanx.
Team 6gc 2005
post Jan 6, 2004 - 6:10 PM
Ghost
Joined Sep 4, '02
From South Carolina
where you ground to?
post Jan 6, 2004 - 9:35 PM
Ok well make sure you have a good ground, (IE, no paint) it'll mess with the ground. Secondly make sure you have your RCA's connected (red and white) and you have your ReMoTe connected. I didnt see you list that and its kinda important. Your amp wont turn on if it isnt connected. Make sure you dont power this to your deck accessory wire. Sometimes the amp needs more power than the deck has to offer, and your deck wont turn on. Go with the power wire off the deck, usually red.
post Jan 6, 2004 - 11:52 PM
i connected my remote wire to my ingintion fuse. it works for me.
post Jan 7, 2004 - 6:25 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
I drilled a hole in the corner of my trunk were the spare tire was and stripped it of all its paint connected a wire and checked for ground by touching 12volt to ground wire no were near the amp(I got a nice spark). so thats covered.
Okay I just saw the remote connection now were exactly do I hook it up and what does it do.
Thanx alot.
This post has been edited by Drocay: Jan 7, 2004 - 6:28 AM
Team 6gc 2005
post Jan 7, 2004 - 6:33 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
I was looking at charts I had for my Deck, Should I connect it to the 12volt constant in back of deck, 12volt ingnition in back of deck, or just the fuse.
Thanx.
Team 6gc 2005
post Jan 7, 2004 - 7:48 AM
12v ignition.
post Jan 10, 2004 - 2:56 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
ok, if you havnt gotting this done yet, on the back of the headunit, there should be a blue wire, you just connect it to there and that should be it.
post Jan 10, 2004 - 5:44 PM
DO NOT CONNECT IT TO THE BLUE WIRE!
99% of the time thats the Accessory wire and it drains from the deck, not the battery, which means if your amp requires more power than ur decking is giving out, it'll turn ur deck off.
post Jan 10, 2004 - 5:58 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
12 volt ignition is the Gray wire 3rd one from the ground which is black, I got my amp to work but now the sub isn't doing anything and I'm really stumped all my wiring is right and I've checked it twice so I'm not real sure.
Team 6gc 2005
post Jan 10, 2004 - 6:27 PM
What I would recommend is to use the "usually" red wire which is the power_on wire for the deck. So that when u turn ur deck on, the amp goes on too.
To troubleshoot, check for power on ur amp. Usually there will be an indicator light which shows power, but sometimes no. So if you connect the power wire and theres a spark, bingo.
Check to make sure that the amp is not only getting power and turning on, but also getting a signal from the deck. If you have per-amp out puts then make sure theres not a setting on your deck which can turn them on and off.
post Jan 10, 2004 - 6:47 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
I know that the amp is getting power and is functioning correctly because It has a dual indicator led green for good and red for protect. When I turn on my stereo the green light turns on and power is good to go, i also checked the RCA wires and they seem to be good to go so I'm just confused.
Team 6gc 2005
post Jan 12, 2004 - 2:22 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
Do what supersprynt said...make sure your pre-amp out is turned on. If your getting power to amp and to deck then its the sigal somewhere...if its not the wiring then its either the speaker or you just have to turn something on that hasnt been turned on yet.
post Jan 12, 2004 - 10:03 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
Also make sure the gain control on the amp isn't turned all the way down.
post Jan 13, 2004 - 5:18 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
Thanx alot u guys I finally finished and AudioFreak thanx for the info I felt like an idiot when I remembered I never Adjusted it.
Team 6gc 2005
Lo-Fi Version Time is now: February 25th, 2025 - 4:09 PM
