> beeping from open door
post Jan 6, 2004 - 6:24 PM
97celicaca
Joined Oct 12, '03
hey does anyone know how to stop the door from beeping when the driver door is open when the car is on accessories? I find it really annoying. TY
post Jan 6, 2004 - 7:10 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Put some dynamite in the door and blow it up, that always works smile.gif j/k
Im sure there is a wire somewhere that all you have to do is cut it and the noise stops.
-Chucky
post Jan 6, 2004 - 7:12 PM
SpedToe169
From Dallas, Tx
I cant remember exactly how it works but there is a connector on the ignition switch (a little 2 pin one) that is the 'key in the ignition' switch. Unplug it and the car won't know when the key is in. I think that'll eliminate what you're talking about.
post Jan 6, 2004 - 7:14 PM
QUOTE (SpedToe169 @ Jan 6, 2004 - 4:12 PM)
That can cause problems if you leave it unplugged though...without that wire, your steering column will lock and stuff. wink.gif
post Jan 6, 2004 - 7:18 PM
97celicaca
Joined Oct 12, '03
hmm... any other solutions? can u open the little button thing in the door well n do somethin with that? the thing that senses if the doors is closed n when its pressed stops the beepin etc.?
post Jan 6, 2004 - 7:19 PM
SpedToe169
From Dallas, Tx
U sure??? I've been driving with it like that for the last several thousand miles. I think the steering lock is controlled by the actual mechanicals of the ignition switch. It would be too much of a liability for toyota to have it electrically controlled....kinda like having electric brakes....what if the battery goes dead? Steering locks and you have no brakes? That would suck!!!
post Jan 6, 2004 - 8:25 PM
QUOTE (SpedToe169 @ Jan 6, 2004 - 4:19 PM)
You must be right. I just assumed that it used the key-in wire because I was able to start my car but the steering would lock up unless the key was in the ignition. wink.gif
post Jan 6, 2004 - 8:59 PM
Why do u have the door open with the key in so much?
post Jan 6, 2004 - 10:15 PM
95celgt
Joined Oct 5, '03
From South TX.
I found this on my convertible but try it anyway...
take the interior quarter panel off, look by where the button is, there should be wires comming from it.
It has a male/female connect....so disconect it and there wink.gif
post Jan 6, 2004 - 10:51 PM
97celicaca
Joined Oct 12, '03
QUOTE (Supersprynt @ Jan 6, 2004 - 8:59 PM)
so i can listen to music while doing other stuff that requires my door being open
post Jan 6, 2004 - 11:29 PM
Turn your key to the ON position and the beeping will stop.
post Jan 7, 2004 - 9:59 AM
SpedToe169
From Dallas, Tx
That works, but it leaves the ignition and ecu on. More of a drain on the battery and not really good for stuff.
post Jan 7, 2004 - 1:09 PM
Besides draining the battery which its designed to do, whats it bad for? Ur electronics are on all the time, having the car off but stuff on doesnt do ne thing. Only thing it is going to do is drain teh battery, and if u have ur system blaring its going to go pretty quick, just dont have the system on.
post Jan 7, 2004 - 1:21 PM
LatinKraze
Joined Oct 22, '03
I personally wouldn't bother to stop the beeping. I just use the stereo in my home. It does seem like a good project tho.
post Jan 7, 2004 - 2:03 PM
97celicaca
Joined Oct 12, '03
QUOTE (Supersprynt @ Jan 7, 2004 - 1:09 PM)
its not necessary to have it on the ON position so why should/would i do that
post Jan 7, 2004 - 10:09 PM
YellowTwo
Joined Jul 25, '03
From Santa Barbara, CA
QUOTE (97celicaca @ Jan 6, 2004 - 7:51 PM)
Yeah I do that a lot too so that would be a good idea to disconnect it. Especially when it's hot and stuff and you're just waiting in your car listening to music...
post Jan 7, 2004 - 10:35 PM
QUOTE (97celicaca @ Jan 7, 2004 - 2:03 PM)
OK think about that for a second. You want the beeping to stop, so the easiest way of doing that is to turn your car on. The beeping will stop, but ur car wll be on. Its not going to drain the battery SO MUCH more faster, but its going to what you want it to.
I dont know what you do for so long that you want the radio on and the door open but if your working with any electronics in your car you definately should have the battery disconnected.
So in conclusion, the reason you would do that is to stop the beeping which you so much desire. I dont think you have the know how to be taking your car apart.
post Jan 7, 2004 - 10:43 PM
97celicaca
Joined Oct 12, '03
QUOTE (Supersprynt @ Jan 7, 2004 - 10:35 PM)
[QUOTE=97celicaca,Jan 7, 2004 - 2:03 PM] [QUOTE=Supersprynt,Jan 7, 2004 - 1:09 PM] I dont think you have the know how to be taking your car apart.
thats great....your comment was pointless and unproductive....obviously u also dont "have the know how to be taking your car apart" if your only advice is to put the key to the ON position...how origional...you think you can say something productive some time? thanks
post Jan 7, 2004 - 10:48 PM
Your sucha lil prick. You love starting with people. First off, I did my own swap. So your comment that i dont have the know how to be taking my car apart is complete garbage, and everybody knows that, including yourself. I'm right, you dont have the know-how. Secondly, my comment was the best comment you got. Its the best solution to your issue. You want your beeping to stop, unless you plan on ripping apart your dash and stuff, its not going to stop. Or, you can turn the key, and your car will be technically on.
Maybe you just dont understand what im saying. Take the key, and instead of having on ACC, go to ON. NOT START! I'm not saying start your car I'm saying turn on your dash and fan and stuff. Thats all that changes, so instead of having JUST your radio on, you'll have a few others things on, like a few lights on your dash and stuff. Its the quickest and easiest solution to your issue.
So you wanna come at me with non-sense, like I dont kno what im talknig about, then fine you spit ur garbage. But you above all people know thats all your spitting.
This post has been edited by Supersprynt: Jan 7, 2004 - 10:50 PM
post Jan 7, 2004 - 10:51 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
97celicaca if u goin to start s**t how bout this:
roll u're f'n windows down and close your door no beeping and u still get your music.
and respect what advise people give u , your not paying for advise people are just tryin to help.
Team 6gc 2005
Lo-Fi Version Time is now: February 25th, 2025 - 7:05 PM
