> 1995 convertinble rear windows and speakers do not work
post Jul 22, 2012 - 1:31 PM
homebuilder
Joined Jul 22, '12
From SouthEast
Hi,
I recently purchased a 1995 celica convertible. It runs great but has a few odd issues. The top goes up and down but the rear windows do not. I tried different switches, no luck. I did not notice any fuses out.
Also, the rear speakers do not work.
I am wondering if anyone else has had this issue, any ideas what it is?
I am guessing a short or splice or something in the wiring, but would love a direction to start looking.
Also, are there lights that illuminate around the top and rear window buttons? If so those are not working either.
Thanks!
post Jul 22, 2012 - 4:26 PM
Lane
Joined Oct 17, '10
From Jax. Fl.
QUOTE (homebuilder @ Jul 22, 2012 - 2:31 PM) *
Hi,
Thanks!
I've noted in the past that the windows have issues with the contacts in the motors. so from what I have seen if you clean the motor contacts they usually work.
post Jan 21, 2013 - 9:20 PM
Bethany_p
Joined Jun 25, '12
From Nc
I purchased my 95 last summer and the windows and speakers were also not working. Someone had unplugged them. The rear windows did not work, toyota place wanted like $800 to fix them. I took them out, ordered a new arm and it worked fine. You can remove the "washer" looking things from the window with a screw driver and pliers if your careful. The toyota place argued with me that I could not buy this part ( the arm), but I did, just can't remember the correct name for it. I found it from the guys on here though. It was an easy fix! Good luck. Remember to always put your top up, before you put the windows up!
post Jan 22, 2013 - 9:10 PM
homebuilder
Joined Jul 22, '12
From SouthEast
QUOTE (Bethany_p @ Jan 21, 2013 - 10:20 PM) *
Thanks for the response. Can you let me know where they unpluged the speakers?
The arm you replaced, it was bad on both sides?
I guess once I take apart I will find out whats going on...
post Jan 22, 2013 - 9:57 PM
Bethany_p
Joined Jun 25, '12
From Nc
You unscrew the back panel that the seat belt goes through. There was a white speaker plug back there and I just plugged it back in. Both sides were bad and I think whoever did it thought they were unplugging the windows because they didn't work. Both of my rear windows were off track and the little white rollers were broken (that arm that you can order has new rollers with it) It's a pain to get back in, but not $800 bucks worth! Don't forget to grease the replacement wheels!
post Jan 22, 2013 - 10:12 PM
6GenCircleLghts
Joined Jun 2, '08
Where I have it circled I think that's the quarter windows plug, I unplugged it once and it most certainly stopped my quarter windows from going up or down. And the white plug to the right is for your rear speakers. biggrin.gif
Lo-Fi Version Time is now: November 23rd, 2024 - 3:52 AM
