gauge cluster, simple gauge cluster question |
Jul 25, 2012 - 11:28 AM |
Enthusiast Joined Feb 28, '03 From So-Cal Currently Offline Reputation: 1 (100%) |
hey guys, i was wondering if the JDM clusters i see on ebay are simple plug and play or will i need to modify things for it to work on my 6th gen. i have a 94 GT and im looking to buy a new one. thanks in advance!
Jul 25, 2012 - 11:33 PM |
bump..
i just want to know if this will be a simple plug and play for my car. i have a 94 gt 5SFE manual transmission. http://www.ebay.com/itm/JDM-TOYOTA-CELICA-...#ht_2376wt_1188 This post has been edited by celicaracer8o5: Jul 25, 2012 - 11:34 PM |
Jul 25, 2012 - 11:44 PM |
I don't think it'll be calibrated right for your car. Maybe someone that's been there done that can chime in.
Jul 26, 2012 - 7:20 AM |
They are not plug and play but you can take the speedo and rpm heads out of the caseing and swap them into yours. The wiring is different for the fuel, temp, and boost side due to having the boost guage in there. There is a how-to in the stickies on this forums somewhere that tells you what you need to do to make it work.
Jul 26, 2012 - 8:26 AM |
Thanks Lagos and Box!! I'll look for the stickie.
Jul 26, 2012 - 9:18 AM |
Enthusiast Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
The sticky will make it work if you have patience, that and looking at the actual backside of the circuit board. I have an ST205 cluster in my car and it works. Just take your time and you'll get the wiring figured out. All it is is repinning the plugs.
EDIT: for the cluster you are looking into, I would just swap over the speedo and rpm gauge since you won't have to change any wiring. This post has been edited by jcbass7: Jul 26, 2012 - 9:19 AM |
Lo-Fi Version | Time is now: November 25th, 2024 - 11:42 PM |
