3sgte question, O2 sensors |
Jul 29, 2012 - 9:22 AM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
Hey 6gc,
I'm looking to order new o2 sensors but I have a question. Stock, the st205 has two oxygen sensors; both on the downpipe, one before and one after the integrated catalytic converter. I just purchased a berk downpipe that only has a spot for one sensor. My questions are: 1. Do I need both o2 sensors? 2. Can I replace one of the sensors with an AEM uego wideband? Or will a non-oem sensor throw cause the ecu to throw codes? Help is appreciated! -------------------- |
Jul 29, 2012 - 9:46 AM |
you can ditch the 2nd O2 sensor. Mines got the plug just hanging there without the sensor. Keep the plug so you can make a bridged connector should it throw an engine light (shouldnt though)
on some cars you need it there, with an extended bung to lift it out of the direct exhaust stream but not ours. get rid of it -------------------- Mike W
Jul 29, 2012 - 9:52 AM |
you can ditch the 2nd O2 sensor. Mines got the plug just hanging there without the sensor. Keep the plug so you can make a bridged connector should it throw an engine light (shouldnt though) on some cars you need it there, with an extended bung to lift it out of the direct exhaust stream but not ours. get rid of it Thanks for the input, that's great to hear. This project is expensive enough as it is haha. This post has been edited by enderswift: Jul 29, 2012 - 9:56 AM -------------------- |
Jul 29, 2012 - 12:58 PM |
Enthusiast Joined Nov 24, '07 From Tucson, Az Currently Offline Reputation: 2 (100%) |
hmm I've never seen a second o2 sensor on a 3s. but I have a 97 OBDII with a 3S in it and have only a top o2 sensor. on my downpipe (Berk) it comes with a bung that you can use for a wideband.
Jul 29, 2012 - 7:36 PM |
look at the wires by your alternator, do u see a 2pin plug hanging there with nothing plugged in???
Jul 29, 2012 - 7:40 PM |
all it does is trigger a light on the dash that looks like =[~`~`~`]=
Jul 30, 2012 - 3:31 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
that second O2 sensor is an exhaust cat converter sensor
Lo-Fi Version | Time is now: December 4th, 2024 - 6:42 AM |
