> Fuel filter being a pain...
post Aug 2, 2012 - 6:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yes I searched and found the write up on it, but it barely made mention of the banjo bolt which is causing me nothing but grief. It won't break free. The top of the filter actually caved in before the bolt has given any. Have sprayed it with WD-40, still nothing. Have removed the air box out of the way so I have plenty of access. Using a 6 sided 17mm socket on a 1/2" drive ratchet, it's not slipping. Keeps flexing the filter. It is the ORIGINAL filter, so it's been in place for the last 17 years. Is this just a case of seized stubborn bolts, or is there something I'm overlooking? Don't like to be a bother, but I don't want to go any further and end up damaging the banjo bolt and line if there's something I'm overlooking. Changed the fuel pump strainer earlier, the fitting on the send line was a real pain. Finally got it to break free though. Here I thought the fuel filter was going to be the easy part... Thanks for any help that can be provided.
2001 Miata LS 5-speed
post Aug 2, 2012 - 7:16 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Nah, thats normal...soak it in PB blaster..it'll eventually come out. Your biggest issue, WD-40...When I did my fuel filter, is when I discovered the amaziness of PB blaster
There is a place to put a wrench right under the banjo bolt to stop it from crushing or spinning..but if you already crushed it...yea...
This post has been edited by rave2n: Aug 2, 2012 - 7:18 PM
post Aug 2, 2012 - 7:24 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Yeah it's a right c*nt , for me its the bottom section that wont budge.
atleast if you ruin the top section you can replace the whole filter unit with something easier like 2 barbed hose ends like most cars use
what fitting is it underneath? 1/4 BSPT???
Mike W
269awhp / 273ft-lbs
post Aug 2, 2012 - 7:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
Alright, will get some PB Blaster then. Wasn't expecting the filter to give before the bolt. Replacement Bosch filter I have is sturdy. I figured the Denso/Toyota filter would be sturdy as well.
Already have the replacement filter though, and don't feel like having to modify things.
post Aug 3, 2012 - 11:48 AM
celica74
Joined Feb 8, '10
From North Carolina
our fuel filters have the same problem hondas do. that bolt always gets corroded and freezes up. i run into alot of these. simple way to do it. take out your trusty impact gun and pull the trigger real quick. hasnt ever not worked for me. i would suggest getting the bottom bolt loose first, just the way ive always done them.
post Aug 3, 2012 - 12:18 PM
Box
Joined Feb 23, '12
From Warrior, AL
Sadly I have no power tools. Always have been able to break everything free with just my own strength. Part of the problem is the damn thing keeps moving, if it'd stay still would probably have gotten it by now.
post Aug 3, 2012 - 12:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
Why couldn't Toyota be cheap like Nissan and just use rubbers hoses and clamps for the filter? laugh.gif
This post has been edited by Box: Aug 3, 2012 - 12:26 PM
post Aug 3, 2012 - 1:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
Good news I found a breaker bar. Going to get some CRC Freeze Off, stuff worked great for when I had to remove bolts from a 67 Cadillac that'd never been touched.
post Aug 4, 2012 - 3:16 AM
gotian
Joined Apr 22, '12
From florida
easiest way i found was to remove the bracket from the filter than use two wrenches, one to "turn"the filter and the other to turn the bolt. I say "turn" the filter cause your not really turning it (you dont want to break the fuel line) But youre holding it in place and slightly applying force in the opposite direction when you are trying to loosen the other bolt
post Aug 4, 2012 - 9:32 AM
celica74
Joined Feb 8, '10
From North Carolina
Nissan filters suck. Until i went out and bought some pliers that push the line off. Makes them a breeze
post Aug 4, 2012 - 6:28 PM
trdproven
Joined Aug 2, '05
From Guam
soak it, if you need to. use two flare nut wrenches, take the filter off the bracket. then position your two wrenches like scissors where you just squeeze them together. its doable just dont round the lines,
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 5, 2012 - 10:51 PM
Box
Joined Feb 23, '12
From Warrior, AL
Alright, after soaking if I still can't get it will try the two wrenches approach.
post Aug 5, 2012 - 11:07 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Box @ Aug 3, 2012 - 10:23 AM) *
they did in newer cars. the filter is in the tank and all the hoses are teflon and have barb type fittings
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 5, 2012 - 11:37 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (Box @ Aug 6, 2012 - 1:51 PM) *
just make sure you are turning the wrenches the right way, you may be tightening
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 6, 2012 - 12:38 AM
Box
Joined Feb 23, '12
From Warrior, AL
If there's one thing I do before cranking on bolts, it's making sure I'm turning the right way. One broken off bolt when I was younger was enough to teach me that lesson.
QUOTE (Smaay @ Aug 5, 2012 - 11:07 PM) *
Reason I had said such, recently changed the filter in my brother's 95 Maxima. Was just held in by clamps, took like 5 minutes if that. This has just been a total nightmare.
post Aug 6, 2012 - 4:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
Finally got it out, but the new one is being an equal pain to put on.
post Aug 6, 2012 - 4:35 PM
rave2n
Joined May 29, '09
QUOTE (Box @ Aug 6, 2012 - 4:23 PM) *
Wut? The new should be cake.
post Aug 6, 2012 - 4:59 PM
gotian
Joined Apr 22, '12
From florida
To me the filter is cake to remove and install, now the filter on my accord forget it....
post Aug 6, 2012 - 5:56 PM
Box
Joined Feb 23, '12
From Warrior, AL
Finally got it on. The bracket isn't locked around it from being bent to Hell and back. but I don't care. Ran it for awhile and no leaks, so good enough.
post Aug 7, 2012 - 1:10 AM
trdproven
Joined Aug 2, '05
From Guam
its a pain to put back on, if you are trying to put the hard lines back on with the filter mounted already to the bracket. you have to put it on first without the bracket and the last thing you do is mount it to the wall. reason, just like you said is because the hard lines tend to get bent in a certain way.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: February 17th, 2025 - 9:58 AM
