10 Pages V  « < 5 6 7 8 9 > »
> Just Another GT-4 Build, We'll skip 10 years of shinangians and just get to the good stuff
post Sep 15, 2013 - 11:37 AM
enderswift
Joined Jul 12, '08
I like your approach to this. Using the rear trailing arms and struts to locate the gt4 subframe still leaves room error, but adding this step ensures you have everything lined up on both sides. What thought process did you go through to decide on how tall the new mounts should be?
post Sep 15, 2013 - 12:25 PM
Malek
Joined Jan 26, '09
From Los Angeles
I'll be updating my thread here soon with a few pictures, but i had the same basic approach. I installed the driveshaft and rear end to line everything up. Took some rough relative measurements and threw a design up in solidworks.
For the front mounts, I designed something a little less bulky than building an entire box across the floor pan. I made use of some engineering classes and designed mounts using tubing and triangulation.
post Sep 15, 2013 - 12:40 PM
QUOTE (Malek @ Sep 15, 2013 - 1:25 PM) *
thats pretty much the best way to set it all up IMO.
kinda lines everything up for you. lol
really digging the mount work, mikey. looks like your on your way!
are you planning on producing these on a "one off" kinda deal, or will they be somthing you'll share with the community?
post Sep 15, 2013 - 12:42 PM
qatar11
From Lake Orion, MI
What are you thinking... the sheet metal is too thin to support mounting directly to it... the frame rail on the passenger side is accessible but the driver side has the fuel and brake lines coming down.... color me interested.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 15, 2013 - 12:50 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Are you doing it so you dont have to weld them in? Use the old mounting holes to bolt an adapter plate? to which the new subframe bolts to.
Good idea. Welding under there is a little tight.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Sep 15, 2013 - 1:05 PM
qatar11
From Lake Orion, MI
QUOTE (czwalga @ Sep 15, 2013 - 1:50 PM) *
That's what I'm thinking.. if the frame rail is thick enough, I can drill a hole and capture the "back" part of the new bracket - I would feel pretty good about that arrangement.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 21, 2013 - 8:40 PM
Malek
Joined Jan 26, '09
From Los Angeles
QUOTE (qatar11 @ Sep 15, 2013 - 1:42 PM) *
These are the pictures just from my build thread. They were taken during the process. It gives you a good idea though.
Passenger side. There's a plate welded to the frame rail where the tubing is welded.
The hoop goes up and over and welds to the two mounting points, the point at the top (after the picture was taken) and two points in the tunnel
This is the driver side. Dropped the lines, though there is plenty of space to run them between the tube and the body if wanted.
The rear mounts are basically the same style. Just two boxes welded to the frame rail.
post Sep 22, 2013 - 8:59 PM
qatar11
From Lake Orion, MI
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 22, 2013 - 10:22 PM
Malek
Joined Jan 26, '09
From Los Angeles
I know, doesn't seem like much holding it in there haha but I see the actual bolts/fasteners failing long before the mounts. The tubing used is dom 1.625x.120 and .125 plates for the frame rails. I did some stress tests in SolidWorks and felt pretty confident with the set up even though I don't think the fronts will be tied to the rears like I wanted them to.
If everything breaks on the first launch..well, back to the drawing board haha
post Sep 23, 2013 - 6:54 AM
qatar11
From Lake Orion, MI
QUOTE (Malek @ Sep 22, 2013 - 11:22 PM) *
Dude.. it looks solid... I never thought to use DOM tubing like that under the car.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 23, 2013 - 8:03 AM
czwalga
Joined Sep 27, '10
From pittsburgh
Sure you did. I used DOM right there too; mine just comes through the floor and up to the cage haha.
I think thatll be plenty strong.
This post has been edited by czwalga: Sep 23, 2013 - 8:04 AM
-10 F150
post Sep 23, 2013 - 8:40 AM
Malek
Joined Jan 26, '09
From Los Angeles
I'm working out a forum deal with the owner, Hank to get these produced as a weld-in ready kit. He has the bend profile saved in his mandrel bender and all the dimensions for the mounts. Here's his site Hanksville
They've done some crazy builds. Top notch guys too. They actually like when the customers stop in and watch the work being done. I'm sure they'll do just that front part for you if you wanted.
post Sep 24, 2013 - 6:28 PM
qatar11
From Lake Orion, MI
QUOTE (Malek @ Sep 23, 2013 - 9:40 AM) *
Bend profile saved in his mandrel bender? You are cheating! smile.gif Seriously though... you should probably PM me so I can get one of those...
And now for something completely different:
This post has been edited by qatar11: Sep 24, 2013 - 6:29 PM
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 26, 2013 - 6:39 AM
qatar11
From Lake Orion, MI
Something funny happened last night.....
I got to the end of the book:
Tens years later.... I didn't really know what to do with myself...
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 26, 2013 - 7:18 AM
czwalga
Joined Sep 27, '10
From pittsburgh
When that book ends you drive it... think of stuff you should have done differently, let it sit around and sell it.
Happened with my rx7.
-10 F150
post Sep 26, 2013 - 10:50 AM
qatar11
From Lake Orion, MI
QUOTE (czwalga @ Sep 26, 2013 - 8:18 AM) *
Speaking of... you should probably change your signature.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Oct 2, 2013 - 6:40 AM
qatar11
From Lake Orion, MI
Just a minor update as I am fighting with swapping wheel bearings on the tacoma...
- a pair of the inner tie rods are in hand
- EBC Reds for the GT4 brakes are en route (cross listed with the Supra TT)
- OE Brake Rotors, front and rear, are en route from the UK
I think I found the fuel cell I want to use - its technically "out of date" (it would need to be re-certified for racing) but its discounted nicely.
Fuel Safe 12 Gallon
Should have more after this weekend...
This post has been edited by qatar11: Oct 9, 2013 - 7:17 AM
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Oct 8, 2013 - 1:43 PM
czwalga
Joined Sep 27, '10
From pittsburgh
You wouldnt have any spare E-brake cables laying around would you. The aluminum housing that bolts to the knuckle is destroyed on the drivers side.
-10 F150
post Oct 12, 2013 - 3:19 PM
QUOTE (czwalga @ Oct 8, 2013 - 2:43 PM) *
just FYI, i just recently replaced jenns, ended up picking them up from rockauto. they are pretty cheap, IIRC ~30$ a side.
post Oct 23, 2013 - 5:03 PM
qatar11
From Lake Orion, MI
The me of 2013 is strongly questioning why the me of 2003 felt it was necessary to completely disassemble this relay box... God only knows where those relays ended up...
This post has been edited by qatar11: Oct 23, 2013 - 6:07 PM
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
Lo-Fi Version Time is now: November 28th, 2024 - 10:08 AM
