need help emergency car wont start video uploaded |
Aug 10, 2012 - 9:56 AM |
Enthusiast Joined Apr 22, '12 From florida Currently Offline Reputation: 1 (100%) |
I went out of town 150 miles away from home, I took the celica cause it was running fine and now it wont start. This no start thing is frustrating the hell out of me to no end. 94 gt manual transmission, has a new distributor, plugs, wires, cap, rotor, igniter, new walbro fuel pump, new fuel filter. I need help, I came down here for work and now now I cant go to work for my last day here and I cant get home either, please someone help me.
correction** it will fire up and die right away. and my idle air control valve is functioning properly This post has been edited by gotian: Aug 10, 2012 - 11:26 AM |
Aug 10, 2012 - 10:10 AM |
Can you feather the accelerator pedal to keep it running? Perhaps it has a vacuum leak or a faulty fuel pump. A bad coil or ignitor can sometimes cause the symptoms you are describing as well.
Check the vacuum hoses around the intake manifold if you havent already This post has been edited by Special_Edy: Aug 10, 2012 - 10:11 AM |
Aug 10, 2012 - 10:19 AM |
if i press the gas pedal it dies even quicker
Aug 10, 2012 - 10:50 AM |
it seems like your not getting fuel if it's dying that quickly
Aug 10, 2012 - 11:17 AM |
i dont know why, i just checked the pressure and it has pressure coming from the pump. could the fuel pressure regulator be bad? i've never had one go bad on me before so I dont know if it would do that. im uploading a video on youtube right now
http://www.youtube.com/watch?v=mXSKrQ3_wyc This post has been edited by gotian: Aug 10, 2012 - 11:25 AM |
Aug 10, 2012 - 11:22 AM |
Signs of a Bad Fuel Pressure Regulator
The vehicle engine runs rough and often stumbles and sputters. The engine will not start after ignition. Usually, this problem is encountered in the morning when you start your vehicle. Many times, the engine starts, but stalls shortly after starting. The fuel pump in the vehicle becomes noisy at times. A bad fuel pressure regulator can also result in fouled spark plugs. Last but not the least, the fuel mileage of the engine decreases noticeably. Lately while i've been down here I have had all these signs except i havent checked the plugs. Last night the car was running a little rough under acceleration. Obviously im having the second symptom right now. My gas mileage was crappy coming down here where I used half a tank driving 150 miles where before I would only use 1/4 of my tank. the pump is noisy but thats cause its a walbro. |
Aug 10, 2012 - 12:13 PM |
so can anyone confirm the fpr before I spend 80 bucks on a new one? seeing as how that is the only part of the fuel system besides the injectors that I have not changed I don't know what else it could be
Aug 10, 2012 - 12:37 PM |
Could be a leaking vac hose going to the FPR.
Aug 10, 2012 - 1:24 PM |
so i got the sucker out and there is fuel in the rail but barely any fuel came out of the regulator or the return line.
Aug 10, 2012 - 2:07 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Fill the tank up with fuel a bit more..The walbro could have its feeding tube up a bit to high, and even though it shows that you have gas on the gauge it may not be getting any... Also make sure the walbro is constantly on....wire it directly to 12 volts.
This post has been edited by SupraKid: Aug 10, 2012 - 2:07 PM |
Aug 10, 2012 - 2:30 PM |
so i got a new fpr and im waiting for advance to send me another one because the oring on the regulator is too big and it pinches when you try to install it...bah
Aug 10, 2012 - 5:28 PM |
installed the new fpr car fired up and died again.
anyone wanna help me dump the car into a canal? I'm kinda fed up here |
Aug 10, 2012 - 6:09 PM |
i had a very similar situation in my supra. it was the short hose that comes off the pump to the feed line. it had actually split so fuel was getting to the injectors but once i pressed the gas it died. check that
Aug 10, 2012 - 6:19 PM |
Do what I said....Fill the car up with gas...if that doesn't fix it then wire the walbro to constant 12v, if that doesn't fix it do what Smaay said.
Aug 10, 2012 - 7:03 PM |
The pump is submersed in fuel so yes the pump is sucking on gas also the pump kicks on no problem. We've now narrowed it down to the injectors not spraying so tomorrow I will check that short house in the feed line and then if that checks out I will be looking at the grounds from the ecu and on.
If anyone wants to help me could you tell me where the right grounds to check are? I'm going to take a break from all this since I've been at it since 10 this morning |
Aug 10, 2012 - 7:10 PM |
The pump is on when you are cranking that doesn't mean it stays on when you let off the key, its a separate system.. And with an 1/8th of a tank the pump is not "submerged in fuel".
This post has been edited by SupraKid: Aug 10, 2012 - 7:10 PM |
Aug 10, 2012 - 7:27 PM |
Remove the air intake hose from the throttlebody. Have a friend start the car while you simultaneously spray starter fluid into the intake. This is the only way to verify you have a fuel problem unless you have a fuel pressure tester and noid light set available.
The ECU takes over the ignition system from the ignitor above 400rpm, just a thought. A bad coil or bad ignitor will function correctly until they heat up, which is usually a matter of seconds after the car is started, just a thought. Never ever buy a replacement part unless you can test and verify the part is faulty. If you can get the gas smell off of the FPR you could probably return it citing the fact that "it doesnt fit" |
Aug 11, 2012 - 12:52 AM |
The car will run with starting fluid. And I can return the part that's not am issue for me.
Aug 11, 2012 - 2:00 PM |
okay so i put 5 gallons into the gas tank, primed the pump and started it, nothing its still doing the same issue. i have half a tank now. it will run with starter fluid as i said before. so how do i wire the walbro to a constant 12v in the celica i've never had to do that before except in my rx7.
Aug 11, 2012 - 2:53 PM |
okay so i put 5 gallons into the gas tank, primed the pump and started it, nothing its still doing the same issue. i have half a tank now. it will run with starter fluid as i said before. so how do i wire the walbro to a constant 12v in the celica i've never had to do that before except in my rx7. The local autoparts store should have a fuel pressure tester for rental. I usually go to autozone, its something like a $200 deposit, which of course you get a 100% refund when you bring it back. They also have a Noid set for $20 or $50 I cant remember, which you plug into the injector wire to see if they are firing. Two very good tests although we can be 90% sure its the fuel pump. |
Lo-Fi Version | Time is now: January 5th, 2025 - 10:08 PM |
