> clutch issue???!!?!?
post Aug 11, 2012 - 3:51 AM
CAcelica29
Joined Aug 26, '11
From ventura, ca
today while driving my car started to do some weird things. when going into 1st gear from a stop it would grab and then rev an extra 1k when i was off the clutch and had the same pressure as before in the gas. it did this thru 3rd gear. not sure why just started. going to investigate tomorrow.
post Aug 11, 2012 - 12:20 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (CAcelica29 @ Aug 11, 2012 - 4:51 AM) *
From what your saying it sounds like the clutch is slipping. Though the clutch usually slips in the highest gears first, and rarely in a lower gear
post Aug 11, 2012 - 9:27 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
^^^ stranger things have happened
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 12, 2012 - 3:40 AM
trdproven
Joined Aug 2, '05
From Guam
get a new clutch kit.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 12, 2012 - 12:50 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
ys thats what i was thinking, it a $$$ issue right now. what would your recommendations be for a kit? im looking for something a lil stronger and more durable then oem. are clutch kits for the zz motors compatible since they use a C series trans like my 7afe.
post Aug 12, 2012 - 6:41 PM
trdproven
Joined Aug 2, '05
From Guam
the 7a doesnt do much, i would just get a stock kit or replacement aftermarket kit to keep costs down, idk how the replacement aftermarket ones last since there are many brands out there. You could try getting something simple like Exedy. Other high end brands are like ACT, Southbend, Competition Clutch, etc. but would run you some money.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 12, 2012 - 6:57 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yes the 1ZZ and 2ZZ use the exact same clutch as the 7A. if you got an OEM clutch for the 2ZZ then it should have a higher clamping force than a 7A clutch
post Aug 12, 2012 - 11:51 PM
trdproven
Joined Aug 2, '05
From Guam
^ is it the same diameter so that it can cover the surface of the flywheel exactly, or will it make its new mark?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 13, 2012 - 12:02 AM
CAcelica29
Joined Aug 26, '11
From ventura, ca
QUOTE (Smaay @ Aug 12, 2012 - 7:57 PM) *
i was curious as to this because some companies list clutches for the zz motors but not the 7a. thanks guys.
Lo-Fi Version Time is now: January 9th, 2025 - 1:38 PM
