> car shaking when turning on/off
post Aug 14, 2012 - 10:11 AM
maddskkilz
Joined May 5, '03
From nj
5-spd 99 GT -
When I turn it on the car shakes not too rough and for only like a second but, it is definitely noticeable. Same type of shake when I turn the car off.
Had the battery changed a couple months ago and getting the spark plugs changed this week --> not sure it will make a difference.
Any ideas what it may be, starter, alternator? Thanks in advance.
post Aug 14, 2012 - 10:17 AM
richee3
Joined Jun 29, '08
From Denver
Starter and alternator are not likely causes. Any vibrations at idle or if you rev the engine up? It sounds like a motor mount issue.
This post has been edited by richee3: Aug 14, 2012 - 2:01 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 14, 2012 - 1:27 PM
QUOTE (richee3 @ Aug 14, 2012 - 10:17 AM) *
It sounds lime
lime, that is yummy.
post Aug 14, 2012 - 2:02 PM
richee3
Joined Jun 29, '08
From Denver
1998 Celica GT-
BEAMS Swapped.
post Aug 14, 2012 - 2:35 PM
Your rear mount is bad, probably the front now too.
post Aug 14, 2012 - 7:26 PM
trdproven
Joined Aug 2, '05
From Guam
front for sure
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 15, 2012 - 8:35 AM
maddskkilz
Joined May 5, '03
From nj
thanks a lot. How much do front and rear mounts go for? is it better to source from a junkyard or should I order new ones from Toyota? how difficult is installation?
getting springs and shocks installed this week but, now I'm debating if I should get the motormounts and do it all in one shot.
yes - there is slight vibration at idle and when shifting into 1st/2nd. that's it
post Aug 15, 2012 - 9:57 AM
richee3
Joined Jun 29, '08
From Denver
$40-50 apiece new, not bad at all. I think they're $50 from Toyota and $40 from Rock Auto.
1998 Celica GT-
BEAMS Swapped.
post Aug 15, 2012 - 10:58 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (richee3 @ Aug 15, 2012 - 10:57 AM) *
I think OReilly ended up having the best price in my area. I want to say it was $20 something
post Aug 15, 2012 - 5:26 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (maddskkilz @ Aug 15, 2012 - 11:35 PM) *
front is easy to inspect so as rear.
there are aftermarket replacements for mounts.
installation for front is pancake, rear is a between tricky and PITA, takes some maneuvering.
motor mounts are not related to suspension so it does not have to be the same time, its not like one of those things where you might as well change it while you are doing something else. but you do have to change it eventually...GL
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: December 11th, 2024 - 9:28 AM
