Jan 11, 2004 - 11:45 PM
Enthusiast ![]() Joined Apr 3, '03 From Omaha, Ne Currently Offline Reputation: 0 (0%) |
Come this summer I am actually going to detail my paint for the first time. I know how to prep with a wax remover first before doing anything. My question is on wet sanding. I am going to use 2000 grit paper but my question is does direction matter; circular, up and down whatever. My grandpa owned an autobody shop so I have seen people do this before, and my mom used to work for him so she knows how to do it, but neither or us can remember if I am supposed to use a circular motion like in polishing and waxing or if it doesn't really matter.
John This post has been edited by 94Toy: Jan 11, 2004 - 11:47 PM |
Jan 12, 2004 - 12:35 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
X-pattern
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jan 12, 2004 - 8:08 PM
Enthusiast ![]() ![]() Joined Dec 2, '02 From Gainesville, GA Currently Offline Reputation: 0 (0%) |
if u plan on using 2000, its going to take you forever and a day!
don't do it in a circular motion |
Jan 12, 2004 - 8:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 12, '03 From Chatham, Ont Currently Offline Reputation: 0 (0%) |
I think you'll be ok with 600-800 grit, change sand paper often to avoid scratchs especially when using an orbital sander.
Hey K2 what the hell is an Xpatern?? |
Jan 12, 2004 - 9:58 PM
600-800? Isn't that a little rough. My grandpa used that when he was preping to actually re-paint a car not just bring the stock paint back.
and I'm not doing it with an electric sander. I'm doing it all by hand. Yes, I know that will take forever, but I don't want to get carried away with an electric sander. This post has been edited by 94Toy: Jan 12, 2004 - 9:59 PM |
Jan 12, 2004 - 10:03 PM
it depends. if you are just cleaning it up. use 2000-grit. if you are sanding out scratches or paint runs or stuff use 800. X-pattern is just going one direction then switch and cross, like a X. and yea, use a softblock or hard block, use a power sander only if you are featheredging or stripping paint.
Jan 12, 2004 - 11:21 PM
**** I was thinking you were going to re clear coat, in that case listen to k2. |
Jan 13, 2004 - 2:04 AM
another thing is dont just dive in and try to do like one side at once or something. im sure your grandpa or mom have told you, but a good thing to do is to completely tape off one pannel at a time and go from one corner to the other. dont try to sand corners too much, the corners burn through alot quicker than anyother spot. 2000grit you shouldnt have a problem with eating through the clear coat, but just make sure you do it smart. this is gunna be like a 1-2 week project if you are the only one working on it and dont want to spend more than 3-4 hours a day on it.
Jan 13, 2004 - 3:03 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
I was just about to add a new topic about this but since you started one already about a similar subject I'll just reply to it: I just finished using Mother's California Gold Clay Bar on my car (see picture)
![]() and I swear to you my paint looks like new. You may think your car is clean when you give it a good and thorough wash but its not. Your carwash soap will only remove so much, a lot of stuff is left behind making the paint look dull. See the link for a better explanation. I'm just telling you guys it really works...and works great, it just takes a lot of elbow grease. I used the thing on my whole car. Next thing I'm gonna do is use high gloss wax on it. Clay Bar Explanation |
| Lo-Fi Version | Time is now: September 20th, 2026 - 3:42 AM |
