Window noise, noise around 80 |
Jan 13, 2004 - 2:31 PM |
Enthusiast Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
I've had this problem since i've onwed the car. When I get up to 80 aor more, both windows make air noise up at the top back corner. Is this normal for the car? The rubber where the window sits has a tear in it at both sides, would this be the problem that is causing the noise? Or is it just the cars??
Jan 13, 2004 - 2:32 PM |
Enthusiast Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
It's the tear in the rubber. Gotta seal it up somehow or get new seals. Drive and have ur friend check the tear. Mine has a tear but makes minimal noise.
This post has been edited by LatinKraze: Jan 13, 2004 - 2:34 PM |
Jan 13, 2004 - 2:54 PM |
Enthusiast Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
I have wind noise problems like yours also. Same area, but no tears. Is this occuring through out the year or during the fall/winter seasons?
Mine tends to make noises when it's freezing out. |
Jan 13, 2004 - 5:00 PM |
occurs year round.... what can I use to seal it up?? would clear silicone work, or some other weather stripping type?? I am open to any suggestsion, I would really like to remedy this.
Jan 13, 2004 - 5:13 PM |
I would take it from the junk yard. That's the only thing i can think of.
Jan 13, 2004 - 6:36 PM |
Enthusiast Joined Jun 24, '03 From MD Currently Offline Reputation: 0 (0%) |
I'm not too sure you can do too much about that noise, our cars have a good amount of road noise anyway.
Jan 14, 2004 - 12:34 AM |
Enthusiast Joined Oct 23, '03 From ky Currently Offline Reputation: 0 (0%) |
I had the same problem. I corrected it by taking the door pannel off, and on the left hand side of the drivers side there is a green circular support that you can adjust the window up and down with this in that corner. It takes some time finding the right height, and it doesn't completely take away the noise, but it lessens it.
Lo-Fi Version | Time is now: January 16th, 2025 - 1:47 AM |
