> Replacing Transmission, how to?
post Aug 19, 2012 - 9:29 AM
NOVAKx17
Joined Oct 7, '09
okay okay, i know i have to search and i did.
found lots and lots on how to replace a clutch.
and i'm just wondering, as ive swaped a whole drive train before,
just not the trans. if i am swapping just the trans what is the easiest way to do it,
step by step.
I can't wait to be back in the game (;
--P.S. what transmissions can i mate to the 5s?
6gen parts are hard to come by where i live, i see some 5th gens now and then.
but hopefully i'd like to keep it in the same ball park. so if anyone has a trans for sale
near 15825 in pennsylvania .
This post has been edited by NOVAKx17: Aug 19, 2012 - 9:31 AM
NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold
1997 Celica ST- swapped and sold
2004 Ford explorer xlt 4x4- totaled
1997 Celica Convertible GT- Going Topless (;
(18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi
( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 )
post Aug 19, 2012 - 11:53 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (NOVAKx17 @ Aug 19, 2012 - 9:29 AM) *
step by step.
If you've seen a howto on the clutch, which requires you to remove the transmission...its the same thing, expect you put the new trans mission in...
S54 for the 5s.
post Aug 19, 2012 - 12:44 PM
mkernz22
Joined May 10, '10
From MA
If you read the thread on how to replace a clutch, then you've read the thread on how to take out your transmission because that's what you do when replacing a clutch lol
post Aug 19, 2012 - 7:58 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Remove the airbox and disconnect everything from the top of the transmission. The starter, VSS plug, shift linkage, ground wires and whatever else. Remove the axles from the transmission.
Unbolt the front and rear motormount, as they actually attach to the transmission. Remover the crossmember that they are attached too. Now remove all the bellhousing to Engine block bolts. There may be 13 of them but Im not sure.
Lastly you want to support the engine with a jack and the transmission with a hoist. Make sure they are firmly supported. Remove the Driverside transmission mount. the transmission will now slide sideways from the motor till the clutch clears and can then drop out the bottom of the car.
Installation is reverse of removal.
post Aug 19, 2012 - 7:59 PM
rave2n
Joined May 29, '09
QUOTE (Special_Edy @ Aug 19, 2012 - 7:58 PM) *
Best part is..that sounds easy, but certainly is not as one individual. If you have help...I suggest you get it.
Lo-Fi Version Time is now: November 23rd, 2024 - 8:00 PM
