> What do we do when the wastegate actuator starts to stick open??, Help
post Aug 21, 2012 - 2:19 AM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
wastegate actuator is acting up and sticking open randomly from i time to time, any suggestions? other than garrett turbo with external wastegate biggrin.gif
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Aug 25, 2012 - 12:35 AM
cax_11
Joined Aug 15, '10
Nevis, West Indies
post Aug 25, 2012 - 9:25 AM
well, either you take the downpipe off and see if the flapper is hanging on the downpipe flange, and grind the flange to create more clearance, or the actuator itself could be bad, which you can test by putting 7-12psi to the actuator using compressed air or a bike tire pump, and watch the arm movement.
pretty straight forward stuff.
post Aug 26, 2012 - 12:19 AM
cax_11
Joined Aug 15, '10
QUOTE (presure2 @ Aug 25, 2012 - 10:25 AM) *
ok buddy, I'm pretty certain my actuator is bad, should I try and get a universal one off ebay?
Nevis, West Indies
post Aug 26, 2012 - 8:46 AM
not if you have a stock turbo.
you can find actuators here, alltrac.net or mr2oc...just poke around some.
if its a 20b, i would PM gottagoturbo, he is always parting out gt-4's.
Lo-Fi Version Time is now: February 20th, 2025 - 10:05 PM
