2 Pages V  < 1 2
> Finally tore the Supra engine out, Update 11/6/12 building the engine
post Sep 17, 2012 - 5:28 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
painted the block over the weekend
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 17, 2012 - 5:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
2001 Miata LS 5-speed
post Sep 17, 2012 - 7:48 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
I like it, Might I suggest Black Highlights-
My 4.0L I6 from my '64 Chevy Pickup
post Sep 17, 2012 - 9:32 PM
anonymous
Joined Sep 16, '12
From Louisiana
All the pistons look like they have seen their fair share of detonation. Who tuned it?
This post has been edited by anonymous: Sep 18, 2012 - 7:24 AM
post Nov 6, 2012 - 10:14 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
ok lets get started with the assembly
here is the block, all nice a clean.
This is where the oil squirters go. they spray under the piston to help cool them when the engine is generating phenomenal power!
Squirters installed
Main bearings installed
Lay the crankshaft in the block, going to check clearances
Lay a strip of plastigauge on the journals
Install the main caps in the proper locations, apply the proper torque and check the clearance
Remove the caps and check the plastigauge. it spreads out and get measured for clearance
This shows .002 clearance = perfect!
Remove plastigauge from surfaces and then apply generous amounts of assembly lube and re-install the main caps to the proper torque
Check the ring gap. use a piston upside down and slide the ring down into the cylinder. i go the length of the piston. using feeler gauges check the gap of the rings. the piston paperwork will give you the proper gaps on a spec sheet.
looking at front of block, install new O-rings for oil pump and water pump
Apply a small bead of FIPG for around the oil pump to seal it. This is the first Toyota engine that doesn't have a gasket that I have come across.
Install oil pump
Install new rear main seal in the housing assembly
This is the #1 oil pan.
Apply FIPG around the pan to bond it to the block. dont forget to install the O-ring on the block.
Install Windage tray
Using new gasket install oil pickup
I didnt get a picture but install the #2 oil pan the same way with a bead of FIPG around the boarder.
Flip engine over and install the head studs
Lay head gasket on the deck
Oops, at this point I realized that the washers that get used with the ARP studs will not fit through the head and around the stud like this. What I ended up doing is removing the studs, applying the ARP moly lube to the nut end of the threads and the washers, then lowered the stud through the head and hand tightened them to the block. This way everything was properly lubed all around.
Another shot of the head with 1ZZ-FE shimless buckets.
GSC Stage 2 cams installed.
Looks like i missed a few steps, got the valve covers on, water pump is on and the water line.
Installed Billet timing belt tensioner pulley
Installed timing belt
Install lower belt cover, and accessory belt tensioner
Install upper belt cover
post Nov 6, 2012 - 10:51 AM
Xander_X
Joined Apr 22, '12
From Central NY
I like how there's a Traction Control label on the TB ... it's like ... "Just reminding you, this car has TC. As you were."
99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo
2010 Acura RDX Turbo w/ Technology Package
68 Impala SS Convertable
post Nov 8, 2012 - 6:12 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah, thats all gone, i have the fogger for my nitrous in there now
post Nov 8, 2012 - 6:20 PM
rave2n
Joined May 29, '09
From Gainesville, FL
I enjoy threads like this that you put together.
post Nov 11, 2012 - 2:16 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Smaay @ Sep 17, 2012 - 6:28 PM) *
I would take a metal polisher to those 2JZ letters to make them shiny and stand out smile.gif
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 11, 2012 - 9:31 AM
enderswift
Joined Jul 12, '08
HOW did I miss this thread???
The build looks great, and I like your attention to detail. Please keep posting picture laden updates thumbsup.gif
post Nov 11, 2012 - 3:40 PM
richee3
Joined Jun 29, '08
From Denver
This thread delivers. I can't wait for dyno results and track times. biggrin.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 14, 2012 - 1:56 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i should turn the key tonight
post Nov 15, 2012 - 12:07 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
waiting.
**** Photobucket
post Nov 15, 2012 - 11:06 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
key was turned, started right up. It smoked like crazy from all the residual oil in the turbo and exhaust. sounds awesome. i cant wait to do the final install parts. i didnt have the cooling stuff hooked up. i just wanted to make sure it runs.
post Nov 15, 2012 - 2:50 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Nov 16, 2012 - 6:37 PM
navseal345
Joined Aug 17, '09
From Millard, Omaha, Nebraska
post Dec 11, 2013 - 12:51 AM
cardshark525
Joined Jan 12, '09
From State College, PA
How did this finish up since it looks like the thread hasn't been touched in a year? Did we hit 1000?
post Dec 11, 2013 - 12:10 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
Well....Here is the latest.
On the dyno, oil started puking out of the front behind the crank pulley. After tearing down the engine, i discovered that the machine shop did not clean the block very well and metal shavings went through the engine. it destroyed all the bearings, the oil pump, and my cams. Luckily i was able to salvage the cams with a polish and Polydyne coating. I took the block back to the shop and hand them pull the oil passage plugs (steel balls) clean the block again, and then tap the holes for a real threaded plug.
I replaced the front seal, and all the bearings. Put it all back together and it is now back on the road. I did get a good base tune in the AEM before it died so now i just need some final tuning.
post Dec 11, 2013 - 10:19 PM
cardshark525
Joined Jan 12, '09
Well that's disappointing. Hopefully things will go smoothly from here. Keep us posted.
post Dec 24, 2013 - 12:37 AM
95CelicaST
Joined Feb 5, '05
2JZ - as unreliable as the 3VZE....
Good luck. Want to see some official numbers when you're finished.
**** Photobucket
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 25th, 2024 - 6:37 PM
