> Inspect engine valve clearance on 1ZZ-FE (2003 GT), 60,000 mile maintenance schedule
post Aug 30, 2012 - 10:39 AM
packman
Joined Aug 30, '12
From Meridian, MS
Any guidance on how to preform this will be appreciated.
post Aug 30, 2012 - 10:50 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
get a set of these feeler gauges. Im not sure where to find the min/max for the clearances tho
This post has been edited by Tigawoods: Aug 30, 2012 - 10:50 AM
エキサイティングカーレーシングチーム!
post Aug 30, 2012 - 10:55 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
No those feeler gauges probably wont work. I needed the ones specifically for valves on my 5S. If you use that other set you have to seperate the feeler gauges and you may accidently drop one in the engine and spend the next two days removing the oil pan to retrieve it.
packman
Joined Aug 30, '12
From Meridian, MS
QUOTE (Tigawoods @ Aug 30, 2012 - 11:50 AM) *
Thanks for the suggestion. I do have feeler gauges but no Toyota Repair Manual. I'll be needing step by step instructions as well as some photos outlining the process.
post Aug 30, 2012 - 11:03 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
get a copy of the BGB from toyota. or if you search you can find it on PDF
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 30, 2012 - 11:19 AM
packman
Joined Aug 30, '12
From Meridian, MS
QUOTE (Smaay @ Aug 30, 2012 - 11:03 AM) *
Just downloaded a PDF copy.
post Aug 30, 2012 - 11:24 AM
Special_Edy
Joined Oct 29, '11
QUOTE (Tigawoods @ Aug 30, 2012 - 10:50 AM) *
Those might not work. These are the feeler gauges you use for valve shims.
This post has been edited by Special_Edy: Aug 30, 2012 - 11:28 AM
post Aug 31, 2012 - 2:14 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
on a 1ZZ the straights work just fine. its really easy to check clearances on a 1ZZ. the 2ZZ is another story
Lo-Fi Version Time is now: November 29th, 2024 - 5:30 AM
