Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
you guys crack me up sometimes. ok im not going to say its impossible because anything is with enough money. but for a simple bolt in there is no way you are going to get a V6 and an AWD tranny to fit back there. there is no room for the rear header. just like Kurt already explained. the V6 sits rocked way back so the rear bank is really low. the header has very little room because the steering column is right in the way. the way the 3S-GTE gets away with it is because the intake manifold is back there and it wraps around the high way so nothing is in the way of the transfer case. then you come to the issue of the block mating to the trans. you need to do a lot of machine work to the block to get it to clear the transfer case.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) ![]() |
That's why I've said the rav4 Awd trans will work its been done
If it'll work on a 1mz it should work on a 2gr Only down side is you'll need custom front axles The final drive is the same do the st205 rear diff still work It had a smaller transfer case I beleave due to space issues on the rav4 -------------------- 95 gt coupe, v6 swap weekend toy
99 gt hatch beams swapped wife's 94 st hatch my daily driver http://www.6gc.net/forums/index.php?showtopic=82235 ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) ![]() |
Well, the research needs to start somewhere right?
-------------------- ~bloodMoney
Well, the research needs to start somewhere right? Yes so get to work lol -------------------- 95 gt coupe, v6 swap weekend toy
Kinda hard with everything being 3 hours from me....
![]() Enthusiast ![]() ![]() ![]() Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) ![]() |
Some stuff you might find useful, interesting.?
http://www.youtube.com/watch?v=ixdJFXJcl3E http://www.tunemytoyota.com/forum/showthread.php?t=7354 http://www.youtube.com/watch?v=ria4qnVkzqw http://www.tristatetuners.com/forum/showthread.php?t=90427 -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 4:07 PM |
