> Wrong Ecu, Ecu
post Sep 2, 2012 - 4:54 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
Quick question hope someone answers ... I looked on a couple site but for my ECU i'm not able to find an answer
I'm running 94 Celica, I've place a 4th Gen 3S-GTE from Caldina. I also converted my car from auto transmission to manual.
So what I have is a 94 Celica manual 3S-GTE, I did not realize that the guy who sold it to me sold it with a auto transmission ECU. only realized this cause I ran the serial number on the ECU it its a auto (89661‑21330). and apparently there is a difference cause for the same car manual serial is 89661‑213"2"0.
So my question is does it matter what ECU im using they both have the same pin hook-up. and if it does make the difference, then what would be the symptoms and why it wouldn't work
Thanks guys always for your help
Always fast and going for the look......
post Sep 2, 2012 - 5:02 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
If it matters, the ECU will look for sensors on the trans and if it can't find the auto trans, it will go into limp mode, cutting power and not letting the engine rev over a certain RPM. The ECU might not care if the auto trans isn't there.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 2, 2012 - 5:50 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
QUOTE (richee3 @ Sep 2, 2012 - 6:02 PM) *
well it does rev above 6000 rpm never let it go higher but it like always from the start its dumping super duper fuel like 5-7mpg sometimes you can see the gauge just drop in 10 mins of driving.. would limp mode do that
post Sep 2, 2012 - 7:23 PM
zfjohnson07
Joined Apr 11, '09
could you use a manuel 94 ecu? i'm not sure how that works, but i got a 94 st manaul ecu if you need one.
post Sep 2, 2012 - 7:26 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
QUOTE (zfjohnson07 @ Sep 2, 2012 - 8:23 PM) *
no has to be from a Caldina
post Sep 3, 2012 - 2:01 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
bump
post Sep 3, 2012 - 3:23 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
best get the manual ecu, has a more aggressive tune, and no auto-related ign retardation, otherwise sure, the engine should run allright and hit boost, just wont be the best it can be.
and yes, your gas milage suffers from ign retardation
Mike W
269awhp / 273ft-lbs
post Sep 4, 2012 - 9:14 AM
travisxcore
Joined Mar 24, '11
From 704
I thought pre-obdii ecus where the same except it tries pinging the o/d (which it can't find) causing the bulb to flash (if you have the o/d bulb)? Otherwise if you have obii it'll throw a code and go into limp mode? I could be wrong though.
post Sep 4, 2012 - 9:19 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i wasnt aware that a Caldina came with a manual
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 4, 2012 - 3:56 PM
QUOTE (travisxcore @ Sep 4, 2012 - 10:14 AM) *
You're right, but it's not a pre-OBDII engine in this case.
This post has been edited by SwissFerdi: Sep 4, 2012 - 3:56 PM
post Sep 4, 2012 - 5:49 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
yea they did not allot but there is... any way to convert it to manual
Lo-Fi Version Time is now: December 2nd, 2024 - 9:39 PM
