> BEAMS Swap into 94 st? Someone help please?, wondering if beams motor would bolt up to S53 transmission?
post Sep 4, 2012 - 7:25 PM
chivo28
Joined Feb 14, '12
From Astoria, NY
looking to buy another 6th gen celica. It's an st, and I was wondering if I can perform the beams swap into it? I was wondering if the beams would bolt up to the s53 transmission? I know it bolts up directly to the S54 since the 5sfe and 3sge are identical. If it does, will the S53 be able to hold the power output of the beams? Need someones help please?[/size][/size]
post Sep 4, 2012 - 7:36 PM
richee3
Joined Jun 29, '08
From Denver
The BEAMS will work just fine in a '94 ST. You'll have to drill holes for the passenger side motor mount, as with any other A-series to S-series engine swap. I'm sure the BEAMS will bolt up to an S53, although I'm unfamiliar with it. It might not. I can't say for sure about holding the power either, but I can't see the BEAMS chewing the S53 up. Why not pick up a BEAMS with the factory LSD S54 and not worry about the S53?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 4, 2012 - 10:27 PM
chivo28
Joined Feb 14, '12
From Astoria, NY
QUOTE (richee3 @ Sep 4, 2012 - 8:36 PM) *
I've been looking for one with the 5spd on ebay. found one for $1399. which isn't bad i guess. What about axles? Should I use mr2 cv shafts/axle to withstand the power?
post Sep 4, 2012 - 10:54 PM
Box
Joined Feb 23, '12
From Warrior, AL
Stock transmission should be fine, people have used the stock transmission when they turbo their 7A-FE. The BEAMS only puts out 37 ft. lb. of torque more than the 7A-FE. Provided it'll bolt up you will be good to go, though the transmission for the ST is geared more towards economy than performance.
2001 Miata LS 5-speed
post Sep 5, 2012 - 7:21 AM
^ It wouldn't match up to the C52, since the 3S-GE uses an S-series transmission. Hence why he's trying for an S53.
post Sep 5, 2012 - 9:30 AM
richee3
Joined Jun 29, '08
From Denver
Stock GT axles work perfectly.
1998 Celica GT-
BEAMS Swapped.
post Sep 5, 2012 - 10:14 AM
PhoenixTech
Joined Dec 3, '08
From Summerville, SC
QUOTE (chivo28 @ Sep 4, 2012 - 7:25 PM) *
The BEAMs does not produce near enough power to hurt that transmission. Your only increasing the power by about 80hp. That's nothing, considering you can run an S5x trans on an ST215 GTE at almost 300whp. Your clutch will go before the transmission does.
www.tweakdperformance.com
sales@tweakdperformance.com
post Sep 5, 2012 - 1:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (SwissFerdi @ Sep 5, 2012 - 7:21 AM) *
Ahh ok, I just saw ST and BEAMS and went from there. Being it's the S53 should be fine, considering then the torque difference between the original intended engine and the BEAMS is almost negligible.
post Sep 5, 2012 - 10:43 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
http://www.6gc.net/forums/index.php?showtopic=82764&hl=
post Sep 6, 2012 - 10:38 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
why a BEAMS? a V6 swap will be about 500 bucks cheaper.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 6, 2012 - 12:27 PM
Box
Joined Feb 23, '12
From Warrior, AL
Maybe he's not familiar with the possibility of the 1MZ-FE swap. redface.gif
post Sep 6, 2012 - 2:44 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
well if he doesnt have strict rules i would suggest a 3MZ
Lo-Fi Version Time is now: February 13th, 2025 - 5:50 PM
