> 3sgte cranks but will not start, Possible anti theft mode
post Sep 5, 2012 - 7:21 AM
Joebo003
Joined Aug 23, '12
From New jersey
I swapped in a 3sgte in a 94 celica gt all the wiring done correctly (i hope) and now it cranks but wont start i hae no spark and my injectors r not firing any help would greatly be appreciated ...all lights work on dash so i dont think its the ecu any help would reallly help thanks
post Sep 5, 2012 - 10:10 AM
PhoenixTech
Joined Dec 3, '08
From Summerville, SC
Have you checked your main EFI fuse to make sure it's not blown? Do you have power at your coil and injectors? Also, how did you do your harness. Did you extend it to go through the firewall in the correct location, or did you cut a new hole?
www.tweakdperformance.com
sales@tweakdperformance.com
post Sep 5, 2012 - 8:46 PM
Joebo003
Joined Aug 23, '12
From New jersey
I replaced the efi fuse...... i cut a hole in the firewall and i added the wires from the ea1 plug to the engine harness b cause i did not have the fuse box that mounts to the rad but i jumped the fuel pump relay and im definately getting fuel
post Sep 6, 2012 - 11:54 AM
PhoenixTech
Joined Dec 3, '08
Have you checked to see if you're getting power at your injectors and your coil?
post Sep 6, 2012 - 6:18 PM
Joebo003
Joined Aug 23, '12
From New jersey
No i havent done that yet ill try that and see what happens
post Sep 12, 2012 - 6:46 AM
Joebo003
Joined Aug 23, '12
From New jersey
I got it started but it wont start with the 3sgte ecu i got it started with the 5sfe ecu do i need to repin the 3sgte ecu im using the 3sgte wiring harness i dont think u should have to repin the ecu cause it came from the motor or is it possible i got a bad ecu
post Sep 12, 2012 - 8:57 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
its possible that you got a bad ECU, but im thinking that you need to re-pin for the 3S ECU. i know the injectors are in the same location, but sensors like G1 might be different. you not having any spark is telling me that the crank pos sensor in the distributor is not reading right.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 16, 2012 - 11:45 AM
anonymous
Joined Sep 16, '12
From Louisiana
It sounds like you may not be getting a cylinder position signal (cam or crank position) to the ecu. Verify that you are getting 12v to the coil and to the injectors when the key is on. If so I would suspect either a fried ecu or a cylinder position signal issue.
It is odd that it will start up on the 5sfe ecu. Look at the pinouts for both ecus and see the locations of the g and ne pins. This may hint to your issue.
post Sep 17, 2012 - 7:56 PM
Joebo003
Joined Aug 23, '12
From New jersey
Do u have the write up for the ecu wiring i have no idea what goes where the mechanical part of the swap is easy but the wiring is a pain in the a$$
post Sep 25, 2012 - 4:10 PM
BuiltNotBought
Joined Sep 24, '12
From Cali
Bump. Have same issue.
post Sep 26, 2012 - 7:43 AM
bsamps4
Joined May 16, '10
From Raleigh
Hopefully this topic will help you.
http://www.6gc.net/forums/index.php?showtopic=82196
post Sep 26, 2012 - 8:59 AM
Neon90424
Joined Jan 19, '11
here you go sir
post Oct 2, 2012 - 9:17 PM
Joebo003
Joined Aug 23, '12
From New jersey
I had a someone do my wiring and everything seems ok but it still wont kick over i think i need an ecu does anyone know how to test to see if the ecu is bad or does anyone have an extra 1 laying around that they want to get rid of if so lmk leave a message with ur # im tryin to get this car on the road
post Oct 20, 2012 - 4:34 PM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
What Gen 3sgte did you swap into your car?
post Oct 22, 2012 - 1:57 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
are you sure your timing is correct? that'll so it too...
post Oct 22, 2012 - 10:28 AM
Joebo003
Joined Aug 23, '12
From New jersey
Sorry havent been on here much its a 3rd gen and the problem is solved the place i got my motor from gave me the wrong ecu i ordered a new ecu and it fired right up im starting to clean everything up and almost ready to drive it
post Oct 23, 2012 - 8:46 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
kick ass! i knew it was the ECU
post Dec 4, 2012 - 9:53 AM
Joebo003
Joined Aug 23, '12
From New jersey
Car now runs and drives but its throwing a code 54 i have a front mount setup and i put a pin in the coolant sensor amd the light didnt go off i tried reading up on how to get it out but there are no real answers i need to know exactly what to do to get rid of this light any help would be appreciated
post Jan 14, 2013 - 2:09 PM
Neon90424
Joined Jan 19, '11
I thought you just had to bridge the conectors..
post Mar 11, 2016 - 12:24 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
do this at the ECU connectors. This worked on my car
Lo-Fi Version Time is now: February 13th, 2025 - 5:51 PM
