> Problem with my AMP Help!, Amp wire getting hot.
post Jan 15, 2004 - 1:45 AM
Snyper94GT
Joined Jan 14, '04
From Kentucky
Ok peeps here's the deal. I just got a 94 Celica installed my 2 12" Pioneer speakers from my old car. Bought a wiring kit for this installation and everything. I connected the 12 volt power cable coming into my 500 w amp to the correct spot on my amp. Got everything working and then headed to town as I'm driving to town I smell the burning of electronics yet nothing is messing up still working fine. So I pull over and check the amp. The gold plated connection where the 12 volt was connected was rusted looking and the plastic around it some what melted. The wire itself had melted the plastic sheath right around the connector as well. Now the 12 volt wire is fused as well as the amp itself. But none of the fuses blew or anything when it did all of this. I have disconnected it for now and was wondering if anybody knew what might have caused this and if so how to fix it. Thanks! confused.gif
post Jan 15, 2004 - 2:14 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
wut type of install kit did u use and wut gauge wire for your 12 volt?
Team 6gc 2005
post Jan 15, 2004 - 8:55 AM
Yeah sounds like your gauge is too thin, may need thicker wire.
post Jan 16, 2004 - 4:56 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
QUOTE (Supersprynt @ Jan 15, 2004 - 1:55 PM)
thicker wire would be a good thing. if its a true 500 watt amp you would need at least 8ga wire. i have 4ga running to my system that is only like 600 true watts.
post Jan 17, 2004 - 7:55 AM
celimanST
Joined Nov 15, '03
From mississippi
Never use anything smaller than 8 ga wire. Man, you can catch your car on fire be careful. Also what amp fuse do you have at the battery.
CelimanST
post Jan 17, 2004 - 9:36 AM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
8g Wire or better for any amp. I prefer 4g little harder to route tho.
the 8g about 50c a Foot, and the 4g about 1-1.50$ a foot. I always run a 60amp Fuse. good luck.
DTE
I am a thief.
do not buy anything from me.
post Jan 17, 2004 - 10:58 AM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
QUOTE (Clipsetuner @ Jan 17, 2004 - 2:36 PM)
DTE
You should only run the same fuse size as you amps combined. like my amps fuses are 60 and 30 so i run a 90 amp fuse. if you only had a 30 amp fuse in your amp then you should run a 30 amp fuse in you wire.
post Jan 18, 2004 - 8:34 AM
celimanST
Joined Nov 15, '03
From mississippi
What ever the fuse size is at your battery make sure that the ampage is about 5 amps less this will make sure you want have to worry about any damage to your amplifier.
post Jan 27, 2004 - 5:34 PM
SoundSlut_dotcom
Joined Feb 16, '03
i agree with supersprynt, u need thicker wire.
post Jan 28, 2004 - 1:56 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
I have a 300 watt amp and i use 8 gauge power and ground....i wouldnt advise using anything less. Along with checking the wire gauge and fuse amp ratings, double check that you have enough wire fed into the receptors on the amp, and make sure its all tight too.
Not trying to threaten your intellegence, its just that a wire can come loose easily if you dont double or triple check your work.
Lo-Fi Version Time is now: November 26th, 2024 - 8:20 AM
