> FS ST205 Suspension/Drivetrain Parts & Gen II Timing Belt Covers
post Sep 7, 2012 - 11:12 PM
alltracman78
Joined Aug 9, '06
From Ma
These are all off an ST205 engine set I bought a while back. This is all I have FS from it right now, please don't ask for other parts.
If you're interested in more than 1 thing I'll work with you on the price and I'll obviously combing shipping.
Everything is located in Southeastern Ma if anyone wants to pick stuff up.
*SOME OF THE PICTURES I TOOK FOR COMPARISON WITH ST185 PARTS, THOSE ARE NOT FS. IF YOU'RE NOT SURE WHICH IS WHICH IN THE PICTURE PLEASE LET ME KNOW*
ST205 shifter and base, I don't know if this is any shorter than regular 6th gen shifters or not. I don't think this is a bolt in for a 5th gen [the shifter arm may be but the base isn't]. It is from a RHD, but I don't think that will make much difference.
$30 + shipping
ST205 RHD steering rack. The rack is in excellent condition, there is no visible evidence of leaks [picture of boots shows they are dry and clean inside except for the grease from the inners]. The high pressure line to the pump is completely dry on the outside.
The inner and outer tie rods have no play, boots are in good condition.
Comes with rack, rack mount, hard lines, high pressure line to pump, and boots/clamps for inner tie rods [everything pictured except the outer tie rods].
$15 + shipping each for the outer tie rods [I don't know if these are the same as regular 6th gen tie rods or not].
$50 + shipping for the rack. Does not include outer tie rods.
$65 + shipping for the rack and the outer tie rods.
ST205 Front Swaybar & Endlinks. Links are in good condition, nuts came off with no problem and are included as well.
It is the one on the right in the picture; the thinner one.
$20 + shipping
T205 Front CV shafts. Drivers side shaft is complete and in good condition. No tears in the boots, the joints feel smooth. the splines and thread on the end are good.
Passenger side the outer joint is no good, the inner feels fine, both boots in good condition.
These are slightly longer than the ST185 [5th gen] axles, as you can see in the pic. Perfect for swapping an E transmission into a 6th gen Celica.
$30 + shipping for the drivers side [2nd one down in the picture] SOLD
$15 + shipping for the passenger side, includes good outer boot and the rest of the outer joint if you want it [bottom one in pic]
ST205 Shifter Cables. They both slide smoothly and include the factory rubber bushings on the transmission end.
They also include the mounting bracket and the plate/gasket for the firewall. These are slightly longer than the ST185 cables.
They are the lower cables in the picture [uppers are from an ST185 for comparison].
$80 + shipping SOLD
ST205 Ebrake Cables. Right and left sides. Both are in good condition, slide smoothly and have no rust on the braided cable. It has a plastic coating on the passenger end of the cables.
These are slightly longer than ST185 cables; the mounting points are different, the sliding grommet at the passenger end is smaller and the cylindrical pivot is larger than the ST185.
I think these are the same as other 6th gen ebrake cables but I'm not positive. They are the lower cables in the picture.
$40 + shipping for the pair.
Complete driveshaft from an ST205. This is slightly longer than an ST185 driveshaft, and the carrier bearings/mounts are in a different position.
It's the bottom driveshaft in the pictures [ST185 on top]. All U joints are smooth, both carrier bearings rotate smoothly and the CV joint in the center feels good and has an undamaged boot.
The yoke that slides into the trans and the dust cover are also in good shape.
$30 + shipping. SOLD
Inner and outer upper timing belt covers for the gen II 3SGTE. Both are in good condition.
Inner cover; all the bolt hole threads are good and the cover is unbent. There is some surface rust on it.
Outer cover; the holes are all in good condition, none are broken. The cover is uncracked and comes with the seal. There are some small scrapes on the top of the cover.
$15 + shipping - inner cover
$25 + shipping - outer cover
This post has been edited by alltracman78: Sep 12, 2012 - 10:20 AM
post Sep 8, 2012 - 7:40 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i'll take the driver side (RH) drive shaft.
This post has been edited by azian_advanced: Sep 8, 2012 - 7:42 AM
post Sep 8, 2012 - 7:43 AM
PM sent jeremy.
post Sep 12, 2012 - 10:20 AM
alltracman78
Joined Aug 9, '06
From Ma
Shift cables, driveshaft and complete CV shaft sold.
Still have the rest.
post Sep 28, 2012 - 10:51 AM
alltracman78
Joined Aug 9, '06
From Ma
Still have the rest of this stuff.
Lo-Fi Version Time is now: April 21st, 2025 - 5:49 AM
