> axle difference lsd to non-lsd, need help plz
post Sep 9, 2012 - 12:34 PM
1000_needles
Joined Aug 31, '12
From canada
im gonna get a new non lsd transmission from mr2 1990 ,
i already have lsd e-153 but i burn it,
does my axle will fit in the non lsd tranny ?
(my axle is st185 outer and mr2 inner whit spacer)
This post has been edited by 1000_needles: Sep 9, 2012 - 12:54 PM
post Sep 9, 2012 - 1:02 PM
1000_needles
Joined Aug 31, '12
From canada
i just find this, can someone comfirm that plz ?
¨^In this case, you can use either axles.
LSD axles will fit both transmissions but non LSD axles will ONLY fit non LSD transmissions.
There are a few other was to tell if its an LSD equipped trans. One, pull the speedo drive out and look at the diff itself. LSD diffs are machined, non LSD diffs are left rough casted. Two, look at the speedo drive gear on the diff, non LSD diffs will have a blue colored nylon gear where as LSD diffs will have a yellowish / Orange colored nylon drive gear.
post Sep 9, 2012 - 1:16 PM
post Sep 9, 2012 - 1:33 PM
1000_needles
Joined Aug 31, '12
From canada
hahaha lool,
post Sep 9, 2012 - 11:32 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
if you have axles for a 93+ LSD trans, they will NOT fit a 90 non LSD
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: November 23rd, 2024 - 5:01 PM
