Mounting progressive springs? |
Sep 14, 2012 - 9:41 AM |
Enthusiast Joined Jan 14, '11 From Belgrade Currently Offline Reputation: 0 (0%) |
I just got my new H&R progressive springs, 29964-1, and i'm quite confused on how they should be mounted. There is nothing in the manual about the position of the springs. I think the tighter coils goes up, in which case manufacturer logo is upside down.
I looked at various forums and many people talked to H&R reps... Some of them were told that tight coils goes up, other that tight coils goes down... Any suggestions? |
Sep 14, 2012 - 9:53 AM |
Sep 14, 2012 - 1:12 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
They should be leaning, because due to suspension geometry, your struts don't sit completely vertical, they are infact angled.
on the bottom pic, you should have the tighter coils on the bottom. (left spring is right side up, left spring is upside down) As for the top pic its sort of hard to tell from thepics. When I got my Tien S techs, the larger diameter springs and wider coils at the bottom, so the spring sort of looked like this / \ , just not as drastic. The wider part went on the bottom (I hope that makes sense) -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Sep 15, 2012 - 2:34 PM |
Thanks for you reply, you were 100% right
Sep 17, 2012 - 1:17 PM |
Not a problem!
Lo-Fi Version | Time is now: November 29th, 2024 - 6:24 PM |
