My new project |
My new project |
Jan 28, 2013 - 10:00 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
it has to be simple. be sure you have all the relays and everything too
Jan 28, 2013 - 10:09 PM |
Enthusiast Joined Mar 23, '11 From tyler, tx Currently Offline Reputation: 0 (0%) |
What relays the auto and standert starter relays are the same and no one seems to know
Jan 28, 2013 - 10:26 PM |
http://www.6gc.net/howto/swap_auto_transmission_to_manual
Have you read through this? Might be slightly applicable. -------------------- |
Jan 28, 2013 - 10:44 PM |
Before you go tearing into the dash, assume your wiring is right and check little things like clutch start wire. Or jump some questionable connections and test. Or get a multimeter and try to find the problem that way. This electrical crap is simple but very time consuming sometimes. Now is the time to have patience for sure.
Jan 28, 2013 - 10:55 PM |
FYI he is using the auto wire harnes and I am using the standert harnes
Feb 5, 2013 - 9:33 PM |
Found this in the BGB look at we're the park/neutral postition swith gose to the ecu at pin 2 and the clutch start swith gose to the ecu at pin 11 There are 2 park/neutral postition swiths one on the tranny and on on the shifter |
Feb 5, 2013 - 11:10 PM |
So does this mean you have it fixed?
Feb 6, 2013 - 12:11 AM |
Nop 😭😡😞 every time I get off work it's dark (yes I do have lights) need to geth her runinng I miss driving the celica And i need a 2nd car my Nissan hardbody is about to throw a rod so I need to fix her next
Feb 7, 2013 - 8:36 PM |
Did I every till u all I don't like wiring
Feb 8, 2013 - 11:46 PM |
Will good news today starter turned over the engine 🎉 but then my battery died 😡 so I am done for tonight and battery is on the charger will work on it some more
I swaped the dash with the dash harness and it works |
Feb 9, 2013 - 10:39 PM |
Time to put oil in engine and tranny, install axles, install all body parts, and wash her
Lo-Fi Version | Time is now: December 2nd, 2024 - 1:45 PM |
