> Why you *need* to unpgrade the fuel pump, with nitrous/turob/engine swap
post Jan 15, 2004 - 5:26 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
here is a shot of the inside of my engine
#2 piston at 0 compression. more pics on my imagestation site http://www.imagestation.com/album/?id=4291141257
cause, lean fuel mixture as a result of the factory fuel pump failing while under boost.
when the pump wore out, i turned down the boost to 4psi and limited my driving(drove my beater around)
but the damage was done, the #2 piston was sevearly weakened. after i got my new walbro pump i raised the boost back to normal because the car was running fine except for one thing
soot and condensation was blown out the tail pipe upon initial start up after the car was parked for a few hours
so a few weeks ago i was driving hard making WOT runs and for some reason my boost went up to 12psi and thats when my piston gave out.
there is a whole long story that goes with that night but i'll make another post about that.
good news is im getting a new engine from toyota for a whopping $40(they want me to pay for new plugs, cuz the ones i had in there where not recomended and are being blamed for the damage)
turbo ST, driven 6,000 miles at 8-10 psi normally, and 12psi on the last night.
everything else is perfect, and had i not been cheap and gotten a fuel pump and the begining, my car would still be going strong with out any problems.
so if you are doing major upgrades
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jan 15, 2004 - 5:30 PM
macavely
Joined Nov 4, '02
thanks for showing that.... i seen that happen before the engine is not that same after even if you get all new internals..
post Jan 15, 2004 - 5:35 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (macavely @ Jan 15, 2004 - 2:30 PM)
i kno, thats why toyota is putting in a whole new engine, lol
post Jan 15, 2004 - 7:11 PM
damn another turbo st ...dead.
post Jan 15, 2004 - 8:20 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Can you salvage a piston with ring and sell it to me, so I can put it in this summer? smile.gif If not, that's fine...I'll get forged everything for a little less than $2,000 tongue.gif
post Jan 15, 2004 - 8:27 PM
qatar11
From Lake Orion, MI
MOOOCH
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Jan 15, 2004 - 9:21 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (OOBE @ Jan 15, 2004 - 5:20 PM)
sorry, they are core returning the whole engine when they get the replacement
i would have though, the other cylinders had good compression (207, 0, 180, 208)
This post has been edited by 97sccelica: Jan 15, 2004 - 9:23 PM
post Jan 15, 2004 - 9:33 PM
Good advice, im already looking at the Walbro 255 for the Supra, is that the one you got?
post Jan 15, 2004 - 10:26 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Supersprynt @ Jan 15, 2004 - 6:33 PM)
yes, its made for the supra tt, got it off of ebay for $91. had to splice in two wires and bend the bracket a little
i say dont drive your car until you get it.
only thing i didnt like about the pump is that it is loud
post Jan 15, 2004 - 11:00 PM
FallenHero
Joined Dec 26, '02
From Alabama
loud? what does it sound like?
post Jan 15, 2004 - 11:10 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (FallenHero @ Jan 15, 2004 - 8:00 PM)
sorta like a drill
thats constantly droning
post Jan 16, 2004 - 3:54 AM
boosted_K2
Joined Aug 30, '02
From Michigan
also make sure when your boosting to set it a little on the rich side. leaning under boost is not a good thing, its always good to have a little insurance. thats y toyota set the 3sgte to be rich. you cant lean out the 3sgte motor with the CT26 turbo, its nice for the added insurance.
No but I don't buy it
Cause I'm...
post Jan 16, 2004 - 6:43 AM
Komlofske
From Wahiawa, Hawaii
What fuel pump is recomended if the stock one isn't any good? Also, can the ST and the GT have the same type of aftermarket fuel pump?
post Jan 16, 2004 - 11:48 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (boosted_K2 @ Jan 16, 2004 - 12:54 AM)
i was running rich
12:1 fmu and only a little bit of leaning out on the safc2
Komlofske
any performance/high flow fuel pump will do.
i used a walbro 255lph pump for a supra TT
post Jan 16, 2004 - 11:59 AM
Komlofske
There is a guy on ebay that is selling a Fuel Pump "Venom", I think. He said something about the person he got if from had decided to use two original Fuel Pumps as aposed to this after market one. Does anyone have any information about this?
post Jan 16, 2004 - 12:47 PM
FallenHero
Joined Dec 26, '02
From Alabama
Yea, I remember that venom fuel pump... It's a supposed direct replacement for our stock one. I wonder what it's flow rating is....
post Jan 16, 2004 - 7:49 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Hmmm, I used a Walbro for mk3 Supra (87-92). The stock pump connector fit the Walbro's harness but the stock harness didn't fit the Walbro's connector. Anyway, the Walbro's base pattern is different from the Celica so that pump will stand a little bit crooked to the side. Also, you have to use the panty from your old pump because the one that the Walbro brings has a thicker plastic base so it hits the bottom of the tank and doesn't let you seal the pump. My fuel feed line fitting was so tight, I had to carefully cut it little by little with a hacksaw blade and then connect it with the little piece of hose the Walbro brings. It was a pain in the ass. But at least, and miraculously, it's not loud at all. It sounds cool and you can hear it only a little bit, and outside the car it sounds trippy, kinda like a little swimming pool pump biggrin.gif
Lo-Fi Version Time is now: February 21st, 2025 - 8:54 AM
