> Noisy Brakes, Scraping noise
post Sep 18, 2012 - 1:20 PM
trevoroq
Joined Aug 2, '11
From Kent UK
Hi guys I have a problem with my brakes sounding like there was no pad left but when I checked there was plenty of pad , they scrape when i start in the morning but get better as i go on, I have also had a judder or the ABS cutting in only sometimes when braking normally, the discs are not in the best condition , pitted ,rusty and grooved in places, I am going to try replacing the pads and bleed the system , if that wont work , i will replace the discs. The ABS light comes on at first and goes off as normal, i have tried looking at the speed sensors but they are fixed firm and i don't want to break them if i don't have to. Does any one else have any other ideas, I need to get it retested and get it back on the road. Thanks
1999 1.8 T20 SR
post Sep 18, 2012 - 1:27 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (trevoroq @ Sep 18, 2012 - 1:20 PM) *
1999 1.8 T20 SR
The rotors will always accumulate crap when you park the car which will be cleaned off after the first couple stops, you shouldnt be able to notice it if the car hasnt sat for more than a few days however.
The judder sounds like a warped rotor, take your rotors off and have O'Reilly's turn them for $15 a piece when you replace the pads.
post Sep 18, 2012 - 5:38 PM
trdproven
Joined Aug 2, '05
From Guam
thats just rust/corrosion buildup when it sits, after you've driven for a bit, it should go away. Thats normal. if its just that, you're fine, if theres vibration during braking, and you can actually pinpoint the vibration, that can be a warped rotor, or a skipping whooshing sound, but before you buy anything just make sure.
This post has been edited by trdproven: Sep 18, 2012 - 5:39 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: November 29th, 2024 - 10:06 PM
