![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) ![]() |
what sway bar did you get?
Enthusiast ![]() ![]() Joined Jul 29, '11 From chino, Ca Currently Offline Reputation: 4 (100%) ![]() |
Whitleline because they r 3 way adjustable they are really nice and im going to try bloxx rsx aadjustable endlinks on them because they r only 50 bucks ill let you guys know how it goes
Well I installed my swaybar last night guys I havnt done the endlinks but I will do that tonight and man you guys weren't kidding when you were saying its a pain in the a$$ holy crap it took me and a friend 3 hours to do it but it makes a world of difference I gained about 10 mph in each turn with no tire screech so endlinks today tires next week let's see where I can take my celi guys
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
Bonzai - your sway bar is squeaking from the bushing? if you run out of ideas and grease, many like to use teflon and wrap it around the bar and grease it.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
ya I've seen the teflon tape. my front it is real stiff but c'mon 3,600 miles thats ridiculous. its only really been 2,000 miles since new end links Its been 3,600 miles since I re greased front bushings because I dropped the front subframe to make my clutch job easier.
So is it the endlinks or the swaybar bushings bonzai I bought rsx heim joints they say just shoot them with wd40 every oil change to prevvent squeeking iff you are looking for a solution they r 50 bucks to
who can make custom sway bar end links??
http://www.mazdas247.com/forum/showthread....y-Bar-End-links This post has been edited by BonzaiCelica: Oct 26, 2012 - 12:14 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Enthusiast ![]() ![]() Joined Dec 16, '11 From The Netherlands Currently Offline Reputation: 5 (100%) ![]() |
i got a C-ONE rear swaybar, 19mm. inproved the handeling quite a bit...but i wonder if the front swaybar also needs to be replaced ? did not see any front swaybars for the GT4...
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) ![]() |
I would def find one for the front if the rear is now larger than the front. Without it you will experience bad oversteer at the end of a hard corner.
i did not some track days with it, no oversteer problems.
I envy your limited slip!
I didn't exxperience any crazy oversteer all the chassis needs is some stiffening up front and it wont oversteer bad at all but for a front wheel drive car oversteer is really easy to correct.
i meant end links, custom end links
I picked up rsx adjustable heim joint end links they work good
Lo-Fi Version | Time is now: February 18th, 2025 - 12:30 PM |
