![]() Enthusiast ![]() ![]() ![]() Joined Nov 24, '07 From Tucson, Az Currently Offline Reputation: 2 (100%) ![]() |
So I bought a E-153 and finally put it in my car this weekend (it was not fun at all) and when everything is all said and done, I try to shift the damned thing and it doesn't feel like it is completely disengaging. I've adjusted the peddle and bled the clutch a bunch of times, I have no air, but it still shifts really rough. I have to shut the car off just to get it in reverse half the time.
any trouble shooting Idea's? Kevin |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
id go with the clutch first. it sounds like its not fully dis engaging
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) ![]() |
did you replace your clutch master? the clutch master would need to be primed and might have some air pockets still in there.
-------------------- st205 powered ss3 coupe
did you replace your clutch master? the clutch master would need to be primed and might have some air pockets still in there. it was about a year ago, but it was "primed" not bench primed but still primed... do you think because I switched to an e153, I would need a new master cylinder? like one for the MR2 or something along those lines? |
did you replace your clutch master? the clutch master would need to be primed and might have some air pockets still in there. it was about a year ago, but it was "primed" not bench primed but still primed... do you think because I switched to an e153, I would need a new master cylinder? like one for the MR2 or something along those lines? i believe the GT master should work fine with the e153, but i still have the s54 so im not 100% -------------------- st205 powered ss3 coupe
a friend who has the same set up (and has been helping me a lot) told me he uses a GT master. so I am going to replace it tonight.
Kevin |
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:50 PM |
