Instument cluster and centre console lights not working |
Sep 20, 2012 - 4:05 AM |
Enthusiast Joined Jul 5, '12 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
Hi guys,
I've encountered this all of a sudden. I noticed the lights in my speedo and the lights in the centre console (the air conditioning controls) are no longer working. I have an aftermarket head unit and it's been installed for a month with no issues and I've checked all the fuses with a multimeter and they were all fine. I've done some quick searching too and couldn't find any info. I haven't had any time to do anything but check fuses yet. Has anyone else had this happen before? Everything else works fine, including all the warning lights in the instrument cluster, clock and the lights that indicate the air con is on and which vents are selected. It's basically all interior lights that come on when you have the headlights on. I've got no idea what it could be (hoping it's a cable that's come unplugged) but I'm going to pull out the centre console and instrument cluster and have a good look for anything wrong if I have time on the weekend. Any ideas/advice will be greatly appreciated Thanks |
Sep 20, 2012 - 4:50 PM |
I'm having the same issue but I haven't done anything about it because my speedo and tach are disconnected anyways. Report back what you find! All of my fuses also seem to be working fine.
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Sep 21, 2012 - 1:25 AM |
I also just noticed that the clock doesn't dim when I turn my headlights on as well.
Sep 21, 2012 - 7:56 PM |
Enthusiast Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
well could be a fuse, mine is doing the same thing as well, but i just havent messed with it just yet.
Sep 22, 2012 - 10:18 AM |
Check to make sure the dimmer switch is plugged in. That will kill your gauge cluster lights but not your HVAC lights.
Did you use an adapter harness for the new head unit? I've never hooked up the "dimmer" wire on my aftermarket head unit but that might have something to do with it as well. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Sep 22, 2012 - 12:03 PM |
mine was a fuse, cluster panel. checked it today
Sep 22, 2012 - 4:25 PM |
mine was a fuse, cluster panel. checked it today Which one is that? Is it under the dash or in the engine bay? What's it called in the diagram? Thanks -------------------- 1993 Celica GT Coupe - sold
Sep 22, 2012 - 6:18 PM |
Under dash top left corner 7.5
Sep 23, 2012 - 12:45 AM |
Got it, going to check it tomorrow.
Sep 25, 2012 - 6:17 AM |
Enthusiast Joined Aug 30, '12 From New Jersey Currently Offline Reputation: 1 (100%) |
Got it, going to check it tomorrow. I had the same problem with the 94 I just bought for my son. I found the fuse was blown but when I put the new one in it blew straight away. I took a look at the wiring under the dash and there was a bunch of burnt insulation. After a complete dash removal and a swap of the main harness ($40) on eBay ) it looked like the previous guy had wired in his head unit wrong and shorted the instrument lighting, the only way he could have done such major damage to the harness would have been to put a bigger amp fuse. So, if your fuse keeps blowing check the head unit wiring and check your harness for damage. |
Lo-Fi Version | Time is now: November 30th, 2024 - 7:09 PM |
