HELP! 3sgte swap. Engine won't idle and engine shuts off when |
Sep 21, 2012 - 8:05 PM |
Enthusiast Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
So I'm finally almost done with the swap ran it today, no codes but engine dies unless my foots on the gas and when the fans turn on the engine shuts off! Had the harness converted by dr. Tweak but it's too late to call and ask. I'm at the end of my rope with this thing and it's gremlins! Any ideas would be very helpful
-------------------- Lift Addict!! ^_^
Sep 28, 2012 - 11:36 AM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
Sounds like you left your efi resistor pack out of the mix. Try to locate it. Its a little silver box with heat baffles on it. should have a spot to plug into your harness.
Sep 30, 2012 - 10:42 AM |
Well I got it figured out thanks to the guys at tweak'd performance. Found out that it was my attempt at wiring in the 3s extra under hood fuse box for the intercollegiate relay that was screwing with the efi relays ground path. Problem solved! No to get the last 2 issues figured out so I can drive her!
Lo-Fi Version | Time is now: November 24th, 2024 - 1:21 AM |
