timing belt ? |
timing belt ? |
Sep 27, 2012 - 1:06 PM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
morning everyone i have a bad leak and its come to my attention from mostly the oil pump seal area so i know digging in there is not going to be fun or easy but i was wondering should i change the timing belt and water pump if im going to change that seal since its on the way or basically right there. what parts should i buy from i want reliable parts and oem is expensive but thats what i usually get anyway. so i need to know if anyone has advice and also links to guides on how to change everything properly should i change any other seals near that area example cam seals or anything like that also tensioners and the other belts im going to change. its a 1999 celica gt with a 5sfe 2.2l 97k miles and im not 100% sure if the previous owner has done the timing belt and water pump change yet.
Sep 27, 2012 - 1:21 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
The correct anwer would be, "Yes".
Do it all while you're in there if you can, because most of it needs to be removed to even gain access to the oil pump seal anyways... and its a big job you don't want to have to do it all over again any time soon. -------------------- |
Sep 27, 2012 - 1:23 PM |
If it only has 97k, I doubt if the previous owner did them. If it was me, I would change the belt and two pump as well as all corresponding seals. The fewer times you have to take the engine apart, the better.
Sep 29, 2012 - 12:29 AM |
hey richiee if its ok with u can u get me the part numbers that i need and do u know where i can get these parts oem i dont wanna get autozone i like toyota but its pricey but in know some places that sell the toyota oem parts for cheaper. so whats the seals i should replace while im in there besides oil pump.
Oct 1, 2012 - 8:35 AM |
Enthusiast Joined Jul 26, '12 From arkansas Currently Offline Reputation: 0 (0%) |
oreillys has the the entire kit for timing belts which includes the tensioners for around fifty dollars.
Oct 4, 2012 - 4:36 PM |
its not the same as toyotas tho?
Lo-Fi Version | Time is now: November 24th, 2024 - 12:41 AM |
