> transmission fluid, which one should i use?
post Sep 28, 2012 - 4:10 PM
celicaracer8o5
Joined Feb 28, '03
From So-Cal
hey guys, so im replacing my clutch today after im off of work and im wondering which transmission fluid to use. any help? thanks guys!!
post Sep 28, 2012 - 4:25 PM
richee3
Joined Jun 29, '08
From Denver
75W-90, and our trannies love Syncromesh.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 28, 2012 - 4:41 PM
celicaracer8o5
Joined Feb 28, '03
From So-Cal
o'reilly's should carry that right? gotta go buy some before i get home.
post Sep 28, 2012 - 4:53 PM
richee3
Joined Jun 29, '08
From Denver
I believe they do. I'm using 1 quart of Syncromesh and two quarts of Mobil 1 75W-90. I've been told that Royal Purple makes a difference as well, but I'm too afraid to run the stuff. I've heard too many horror stories about seals failing.
1998 Celica GT-
BEAMS Swapped.
post Sep 28, 2012 - 7:43 PM
Rusty
Joined Nov 5, '07
From New Zealand
5S-FE & 3S-GE both use a S54 transmission
post Sep 28, 2012 - 11:27 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (richee3 @ Sep 28, 2012 - 5:53 PM) *
Yup, royal purple synthetic blew out my oil cooler gasket, oil pump gasket and rear main seal all within a week of changing the oil.
post Sep 28, 2012 - 11:30 PM
Syaoran
Joined Jan 4, '12
From US
I used 2 and a half qts of Synchromesh in my S54. Shifts a lot better now.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Sep 29, 2012 - 12:25 AM
mi645
Joined May 23, '12
From northridge,CA
where can i get this synchromesh stuff i really wanna try it.
post Sep 29, 2012 - 12:35 PM
Syaoran
Joined Jan 4, '12
From US
Any autoparts store, Advance Auto, Autozone and Pep Boys usually carry it.
post Oct 4, 2012 - 4:08 PM
mi645
Joined May 23, '12
From northridge,CA
i found synchromesh by penzoil that works? and i have in my car already redline mt-90 is that the correct fluid or no?
post Oct 5, 2012 - 9:31 PM
travisxcore
Joined Mar 24, '11
From 704
So whys everyone use 75w90 when the S54 calls for 80w90?
As for the whole Royal Purple Synchromax thing, I think the issues are because people use the "manual transmission" version which is actually for manuals that call for ATF. Its a lot thinner and breaks down under heat easier. They do however make synchromax 75w90 (and 75w140 for all you that like to watch out for high temps) which I assume would be fine our cars.
QUOTE (mi645 @ Oct 4, 2012 - 5:08 PM) *
Reline MT-90 is right, a lotta Mr2 guys swear by it. Personally, I just bought the cheap stuff. $5.99 a quart. Lol. I did however buy a quart of royal purple synchromax 75w140 to mix with it.
This post has been edited by travisxcore: Oct 5, 2012 - 9:37 PM
post Oct 5, 2012 - 11:36 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
75-90 80-90 same crap to me. I use whatever i carry at my work which is ams oil 75-90 syn. I use the napa brand 80-90 stuff also.
2nd Gen 3s-gte.... It lives!
97celiman
post Oct 6, 2012 - 6:08 AM
richee3
Joined Jun 29, '08
From Denver
QUOTE (travisxcore @ Oct 5, 2012 - 9:31 PM) *
What's your source? Every source I've ever seen for the S54 says 75w-90. Then again, my car is missing the owner's manual so I've never seen what it specifies.
Either way, 75w-90 and 80w-90 are close enough. You'll never hear "You need a transmission rebuild since you were using 75 instead of 80." And most guys here on the boards and the MR2 guys have been running 75 long enough to prove that there are no harmful effects.
This post has been edited by richee3: Oct 6, 2012 - 6:20 AM
1998 Celica GT-
BEAMS Swapped.
post Oct 6, 2012 - 7:03 PM
travisxcore
Joined Mar 24, '11
From 704
Alldata and double checked with O'Riley's when I went in to pick up a clutch alignment tool.
It's funny cause O'Rileys said "75W90 except for 2.2L, use 80w90" and that was while looking up under the GT. But as you stated theres not much of a difference at all between 75 and 80.
post Oct 6, 2012 - 7:39 PM
richee3
Joined Jun 29, '08
From Denver
Weird. Like I said, I don't have an owner's manual to reference, and all sources I've seen online specify 75W-90, apart from the ones that only say API GL-3.
1998 Celica GT-
BEAMS Swapped.
post Oct 6, 2012 - 11:10 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
gl-5 stuff is fine also
97celiman
Lo-Fi Version Time is now: November 24th, 2024 - 9:56 AM
